1965 Lemans Gets Booosted - Page 8 - Beyond.ca - Car Forums
Page 8 of 9 FirstFirst ... 7 8 9 LastLast
Results 141 to 160 of 169
Thread: 1965 Lemans Gets Booosted
  1. #141
    Mar 2007
    Edmonton area
    Has wheels
    Still only 7lbs and 14.5°. All plugs looked good, with #8 being the "worst". It is the most carboned / sooty looking and even then, still not terrible
    At a loss really, not really sure what else I can check before yanking the motor. Going to re test the injectors just to be safe and cross that off the list.
    Open for suggestions haha.
    Plans to yank, hopefully find the culprit, fix, button back up and then turn it up.
  2. #142
    Feb 2020
    Edmonton
    Quote Originally Posted by brucebanner View Post
    Why not just pull the heads with it in?
    A leakdown test should also show a headgasket. I cant see how you went from good rings to bad rings, that would be the last thing Id check imo. But a leakdown will also help with ring diagnosis.
    If I had known you guys would end up being such bitches, I would’ve opened the parenting forum.
  3. #143
    Mar 2007
    Edmonton area
    Has wheels
    I'm not sure either but fluids are all good and the crankcase pressure has to be coming from somewhere. There has to be a cause.
  4. #144
    Aug 2002
    992 T-hawk Golf R
    +1 for Leakdown Test. I’ve blown up a lot of engines in the past, leakdown test is your friend.
    I like neat cars.
  5. #145
    Mar 2007
    Edmonton area
    Has wheels
    Cylinder 7 & 5, broken pistons, some debris in the oil pickup..
    Just my luck, digging in more tomorrow to see if anything else shows up.
  6. #146
    Sep 2008
    Turbo stuff
    Not enough ring gap? 7psi and 14 degrees is pretty tame.
  7. #147
    Mar 2007
    Edmonton area
    Has wheels
    Quote Originally Posted by Sentry View Post
    Ranged from .019 - .021 top and bottom .025
    I'll be the first to say, I don't have the experience with this as it is my first ls turbo set up but I'm leaning towards tight
    Either way, based off boost and timing, still shouldn't of been an issue.
  8. #148
    Aug 2011
    Strathmore
    2005 Dirtymax
    Yeah definitely too tight.. would have wanted more in the .025 range for the top.
  9. #149
    Sep 2008
    Turbo stuff
    What part of the pistons broke? In my experience, the two types of ring land failures are pretty distinct. End gap too tight (especially on the top ring) will lift the top land off.
    Detonation will crack the ones further down and the crown will be OK or just show pitting signs of det.
    Name:  Lotus Engine Piston 1 Disassemble 002.jpg
    Either way, your margin for error is a lot smaller with cast pistons.
  10. #150
    Mar 2007
    Edmonton area
    Has wheels
  11. #151
    Sep 2008
    Turbo stuff
    What do the piston tops look like? The failure looks like a detonation one and not a ring gap one, and even though boost and timing were mild, could be something as stupid as bad gas.
  12. #152
    Mar 2007
    Edmonton area
    Has wheels
    Have only had shell 91 in the car.
    Top of pistons oily:
  13. #153
    Aug 2002
    992 T-hawk Golf R
    I would have guessed detonation from that failure as well.
    I like neat cars.
  14. #154
    Sep 2008
    Turbo stuff
    ENHANCE lol, can you get us a better lighting pic of this area?
    This is the detonation pitting you might see, but like I said cast pistons are so fragile sometimes they just bust lands without pitting on the crown. Check combustion chambers too, they will also pit if the det is bad enough.
  15. #155
    Mar 2007
    Edmonton area
    Has wheels
    I should be able to get my hands on some more detailed photos tomorrow. Motor is also at a buddies shop being torn down. As I mentioned before, little out of my depth of experience and I'm out of town for work but I wanted this still moving forward.
    Tops of pistons apparently didn't have any signs of detonation, nor did the plugs.
  16. #156
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Thanks for talking about cars guys. This is really nice, and interesting lol.
    Brucey sorry about the luck though! Hope it gets fixed quick.
  17. #157
    Mar 2007
    Edmonton area
    Has wheels
    I'm glad you're happy there's car talk going on at my expense
    Motors torn down and more findings..
    "Rod bearings look good & same with the rod throws on the crank.
    The crank bearings are done and so are the surfaces on the crank.
    So you need 2 pistons and your choice of a different crank or get this one ground. I would rebearing the whole engine and I would strongly consider replacing all the pistons."
    I don't have many more pics but that doesn't really matter..
    Downtime seems like it's going to be short as replacement parts are being sourced and moving forward getting it back together.
    Hopefully I don't have the same experience shortly after its back together haha.
  18. #158
    Feb 2020
    Edmonton
    This is where I'll say you should just source a junkyard 5.3, aluminum or otherwise. Bolt your stuff on and go.
    But that's just my opinion. I just hope you don't suffer further problems and this isn't costing you an arm and a leg!
  19. #159
    Mar 2007
    Edmonton area
    Has wheels
    Well considering I was hoping for just regular maintenance for a while, it's going to cost me more than I'd like.
    Just want to get it back together and enjoy it for the rest of whatever we have left of the season.
  20. #160
    Mar 2007
    Edmonton area
    Has wheels
    Oh look..
    Have about 40kms on it now, going to change the oil tomorrow and then get some more driving in. Everything seems to be good again.. Fingers crossed.
  1. FS: Oldshool Bug (1965)
    By maximus in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 04-10-2006, 09:44 PM
  2. James Bond's 1965 Aston Martin DB5...
    By /////AMG in forum Automotive News
    Latest Threads: 01-22-2006, 01:54 PM
  3. 1965 Impala
    By holms in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 09-26-2004, 09:42 PM
  4. 1965 Dodge Monaco
    By HiRola in forum Dodge
    Latest Threads: 11-23-2003, 10:59 PM
