Burgman (big scooter) refit - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Burgman (big scooter) refit
    calgary ab
    4x4
    Default Burgman (big scooter) refit
    Well Kids away - need to keep myself entertained.
    Grabbed this little beasty as a runabout. Not exactly little - it's an 05 burgman 650; 600lbs but a lot easier to ride in heavy traffic than a goldwing (that was original plan to buy, until I rode one in heavy traffic - that seller had a tmax - out of my budget, but put me onto the maxi-scoots).
    Got it cheap, because - theft recovery - not insured for theft so not written off thankfully... It's got some issues as a result. And 3 coats of tremclad to disguise it
    After peeling off the duct tape. Yeah This will be fun. Put a new battery in it to get it off the trailer and do some hood-rat rides around the parking lot before bringing it in for teardown.
    So last week or so has been ripping it apart, Learned it's been dropped a few dozen times by the looks of the plastics, some crummy fiberglass repairs - none of them didn't peel when screwdriver was slid behind. The duct tape was hiding a lot more than expected.
    Melted lots of abs pipe connector chunks in ABS cement; and have been patching/fixing. SEM Black trim on the plastics that are supposed to be black, prepping all those tupperware pieces.
    Was intending to just eliminate the key altogether - take away the crackheads favorite screwdriver hole. But after realizing - the only way to get a new gascap/glovebox key - is going to involve ordering the full keyset. (Yeah no kidding - the gascap isn't a screw on; it's a weird burgman specific monstrosity nobody makes). Was in the process of CNC'ing the blockoff plate:
    Name:  burman keyhole v3.png
    Yes that's Nedry from Jurrasic park - initially I wanted to have the teensy play the "Ah Ah Ah! You didn't say the magic word" in gif/wav if someone sat on the bike without NFC unlock. But decided the gif/wav would just taunt the damn crackheads and I'd be having more broken parts to fix. But it stuck in my head so - Let's put it on the plate anyway
    Anyway waiting on suzuki to let me know about that 400$us hunk of rekey kit pain's availability. So not making a 3rd attempt at the block-off plate. 2nd wasn't too bad, still not gretz quality though.
    Bike paints don't show up in most shops lookups; the place across the street does automotive spraybombs cheap. But no bike colors. Went with Suzuki YBA "Pearl Deep Blue" - close enough for me; all the plastics getting painted anyway. Ended up deciding on a Matte clear.
    Here's tonight's first "lets see if I like the look" assembly before I clear more parts to have to redo if I hate it. (Yes the front fenders fighting me and I forgot about the mirrors)
    I'm digging the color.
    Jun 2007
    ATS, XC90
    Nice! You have your work cut out for you but I like the color and looks like fun.
    Cool. I know nothing about these.
    06 S2000
    This is pretty cool. I'd like to see what you do with it.
    My car sounds like shit.
    Ford, Acura
    Hopefully some sick wheelies
    I'm generally cute.
    calgary ab
    4x4
    Quote Originally Posted by schurchill39 View Post
    Haha no, I'm going to drive like an old man it took a decade for the costs associated to the tickets for my last bike to come off
    But it may have done one last night parking lot cruising with no plastic seeing if I did the tuneup right. It's a bit snappy with 100lbs of plastic missing
    Checking the look before tearing it all off again.
    One of the Suzuki dealers found me an ignition assembly - 537$ ouch. No gascap yet. I may have to retrofit...
    calgary ab
    4x4
    First little test-ride to ensure it's together and running right before putting in all those damn plastic rivets/clips/screws in.
    Somewhat concerned after the oil change - pretty much filled the drain pan - (8L capacity); It's only supposed to have 3.3litres so... ? Not milky/frothy but does seem thin (compared to the rotella 5/40 I put in - dont ask it's one of the few with the right ratings for the clutches) but doesn't smell gassy. Not sure what to make of that.
    Was way low on coolant too (and the wrong type). So may do a few more shorter 'neighborhood' test rides before I fully button it up.
    It's weird to ride; automatic and low revving with not typical motorcycle controls is screwing with my brain. After an hour test riding, went to merge onto TCH for a next exit test at highway speed brain was in "motorcycle mode" grab the left 'clutch' stomp on a pedal, twist - that didn't go so good with rear brake being on the left Took me a second to figure out the bike wasn't broken.
    calgary ab
    4x4
    Windshield arrived.
    Added a top case today - bit of a clusterduck however since givi says the b47 will do monokey or monolock; apparently not so much. Not sure if I need a different latch for the topcase or should throw the uglier monolock plate on... May just redrill the bracket, put on the monolock plate and be done with it. But I still dislike the plate, and not intending to have it mounted full time.
    Longest test drive yet to pick it up 60k into surrey along Fraser highway, then back along the TCH.
    Trying to bribe a friend to bail me out on the RFID ignition - can't figure it out, not sure if it's programming or something with the noise in the kill switch wiring - but 13mins and cuts out, set your watch by it, so bypassed for the interim.
    Got some vinyl to hide the lack of windshield trim coming. Not spending 500$+ on that piece. Definitely gotta order the fuel door however.
  1. Yes or no to projector refit?
    By FraserB in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 12-27-2010, 03:55 AM
  2. Girl with scooter crashes into another scooter
    By trev0006 in forum Cars, Bikes, Machines
    Latest Threads: 08-26-2010, 04:50 PM
  3. FS: 2007 Silver Suzuki Burgman
    By kronos in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 04-27-2009, 11:59 AM
  4. Feet too big... pedals too big!
    By natejj in forum General Car/Bike Talk
    Latest Threads: 07-26-2005, 08:31 AM
  5. Big Big Bear! - pic
    By Ekliptix in forum General
    Latest Threads: 12-05-2002, 07:22 PM
