Hood fan condensation issues - Beyond.ca - Car Forums
Results 1 to 20 of 29
Thread: Hood fan condensation issues
    Oct 2007
    YEG
    Lotus and a Honda.
    Default Hood fan condensation issues
    So we had this issue last year where our hood fan was building lots of condensation and pouring onto our gas stove. We couldn't use the fan/stove anytime where the weather was colder then -10.
    Builder came multiple times and after the third attempt found that where the vent goes through the wall was not 100% insulated. They spray foamed it a couple weeks back and said that it was fixed.
    Today -20, and here it starts again. Haven't even turned on the fan today.
    Anyone else having this issue or know anything about it?
    Last year-
    Today
    Cereal Killer.
    @iambrianspilner
    Oct 2007
    YEG
    Lotus and a Honda.
    Pictures of the top vent. Frozen piping and starting to pool. Builder has been contacted but they are a bunch of goofballs that probably shouldn't even be building sheds.
    Last year there was a pool on top of the hood fan.
    Cereal Killer.
    @iambrianspilner
    Cochrane, AB
    Trucks
    Insulate the pipe with foil back fibreglass. Is there a flap inside that vent or the outside wall outlet that is stuck open? If the airflow isn’t blocked while off the cold air is going to pour into your house like a waterfall.
    Sep 2012
    Insulate the entire pipe. You can buy pipe insulation at HD etc.
    Oct 2007
    YEG
    Lotus and a Honda.
    Flap is on the exterior and they checked and confirmed its working properly.
    I've suggested to them why it's not insulated and they say no need lol.
    Will have them purchase some and waste their time coming back.
    Cereal Killer.
    @iambrianspilner
    Feb 2003
    DT 780
    LEXUS LX470
    I wonder if a thermal break would help aka a short section of plastic piping right at the exterior wall to flap connection
    Tap, Rack, BANG!
    Oct 2007
    YEG
    Lotus and a Honda.
    Keep any and all suggestions coming.
    Cereal Killer.
    @iambrianspilner
    When was house built?
    Oct 2007
    YEG
    Lotus and a Honda.
    House was completed November 2019. We moved in the following Feb
    Cereal Killer.
    @iambrianspilner
    Jan 2021
    From the frost/ice build up on the vents it look like a lot of very cold air is flowing directly down that stack. You may need to install a back draft damper.
    Sort of like this: https://www.amresupply.com/part/BDD1...-DAMPER-5-inch
    (you should check into any building code issues for this)
    calgary ab
    4x4
    Tightly sealed house (based on 2019 build) + high efficiency furnace = check your furnace air intake sizing and whether it's obstructed...
    Cochrane, AB
    Trucks
    Quote Originally Posted by AndyL View Post
    Good call.
    Canyonero
    this makes a ton of sense
    Does it?
    I assume the theory is that the house is under vacuum due to undersized or clogged intakes. But flapper in hood exhaust should not be letting cold air in to this extent.
    Mar 2006
    This is the correct course of action. Not sure if it's code in a residential application but typically any duct from an exterior wall needs to be thermally wrapped for 10'.
    Run hood fan 24h/day, problem solved!
    Bicycle
    Quote Originally Posted by MOB68 View Post
    Doesn't all range hoods have one of these by default?
    Jun 2014
    Do you know if that outside vent is facing the windy side of the house? Mines not on the windy side but during the nasty wind weve been getting i can still hear it flap now and then. Could be wind keeping the flaps open and the cold wind coming in non stop with the snow.
    Might want to see if the builder is willing to replace that range hood too. I know they can handle moisture because they suck up a ton of it when cooking but its blowing it directly out and immediately, this is water sitting on potentially many of the electrical connections.
    Builder is going to tell you to fuck off and say this is a labor and materials issue and you are out of warranty.
    calgary ab
    4x4
    Does it?
    The flappers aren't a tight seal... Just like the dryer and bathroom fan exhausts.
    But the drawing cold air in - does point in a direction of this is more HVAC related than fan itself. And we know the HVAC guys have a habit of undersizing the air intake - we also know this is the time of year and conditions where we get warnings from the fire dept about CO & CO2 detectors because - vents get clogged.
    It's a not insignificant draw of air - so it's more likely the path of least resistance for the airflow.
  1. Headlight condensation in Lexus RX
    By 01RedDX in forum Car Care, Detailing and Body Work
    Latest Threads: 06-18-2009, 01:35 PM
  2. Condensation in my headlights
    By Kozikman in forum Car Care, Detailing and Body Work
    Latest Threads: 05-21-2009, 10:26 PM
  3. Headlight Condensation
    By BigBearWest in forum Mechanical
    Latest Threads: 03-08-2007, 08:19 AM
  4. F*#@ing condensation
    By funkedelic in forum Alberta BMW Owners Club
    Latest Threads: 11-14-2006, 10:48 AM
  5. Getting Rid Of Condensation
    By 2K255HP in forum Mechanical
    Latest Threads: 02-05-2003, 10:25 PM
