Hood fan condensation issues - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: Hood fan condensation issues
    Oct 2007
    YEG
    Lotus and a Honda.
    Builder wanted to bring the cabinet company in to start to see what's happening behind the scenes, I guess?
    Told them to wrap the pipe and try that before you get into demo. Pipe is wrapped, cold weather coming in wed/Thurs this week so should know if the problem is solved.
    Cereal Killer.
    @iambrianspilner
    May 2007
    has a stick axle
    @B.Spilner how did things work out for you regarding this issue? In the midst of installing a hood fan and wondering how crazy I should go with the insulation.
    Jul 2013
    Calgary / Alberta
    ‘No need’ is bullcrap. Alberta Building Code says to have first 3m from exterior termination to interior on an exhaust vent to be thermally insulated with at least 1” thick insulation. I’d suggest 2” or double wrapping it with 1” for that entire little bit of hard pipe. Lazy idiots.
    Quote Originally Posted by KRyn View Post
    As crazy as possible.
    Damn, I wish I saw this when it was fresh. For what it's worth anyone in this situation should also make sure the air path is not obstructed on the inside. I had an issue with a bathroom fan dripping on really cold days, everything was insulated and seemed fine on the outside. Then I realized the dumbasses who installed the fan used screws to attach the duct, and put one in too close to the backdraft flap inside the fan housing. It severely reduced the airflow. I fixed that like 8 years ago and it never happened again.
    dv/dt
    Quote Originally Posted by zieg View Post
    Good to know, I had issues in -30 with both my bathroom fan and my range fan last winter.
    Feb 2003
    DT 780
    LEXUS LX470
    Check your fresh air intake for obstruction. If you starve your furnace of fresh make up air then it will pull a vacuum and any orifice in your house will start sucking more than a kardashian
    Tap, Rack, BANG!
    May 2007
    has a stick axle
    Quote Originally Posted by jeffh View Post
    Noted, I will go real crazy and at least double wrap it.
    Dry fit the pieces first. Then use aluminum tape or mastic to seal the pieces. Then attach and seal those pieces. Don't mastic to the fan. Then duct wrap as much as you can. It also helps to keep the fan noise down.
  1. Headlight condensation in Lexus RX
    By 01RedDX in forum Car Care, Detailing and Body Work
    Latest Threads: 06-18-2009, 01:35 PM
  2. Condensation in my headlights
    By Kozikman in forum Car Care, Detailing and Body Work
    Latest Threads: 05-21-2009, 10:26 PM
  3. Headlight Condensation
    By BigBearWest in forum Mechanical
    Latest Threads: 03-08-2007, 08:19 AM
  4. F*#@ing condensation
    By funkedelic in forum Alberta BMW Owners Club
    Latest Threads: 11-14-2006, 10:48 AM
  5. Getting Rid Of Condensation
    By 2K255HP in forum Mechanical
    Latest Threads: 02-05-2003, 10:25 PM
