Condensation inside - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 55
Thread: Condensation inside
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Default Condensation inside
    This winter is our first winter with a working humidifier (it was set at 25% yesterday and i turned it down to 20%) and the condensation is on almost every window, also its very hard to open the sliding door although I think this may be an issue with ice build up under the door somehow. Does anyone also suffer from this? the humidifier and fan run almost constantly.
    Quote Originally Posted by BavarianBeast View Post
    Could have been over 60% if I wasn’t a paper hand bitch
    Finding the optimal humidity is a little complex, changes for each house. Lowering the humidity in your house is very easy in winter. The air outdoors is dry as a bone in these temps. Turn off humidifier, open one window a crack and run one bathroom exhaust fan for a day and it'll drop.
    How shitty are your windows though?
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    This was the chart that my builder gave me.
    The humidistat controller is usually not very accurate. You should get an actual humidistat and use that to gauge what the actual humidity is and then adjust your dial controller to click once you're where you want to be.
    It's -25°C at my place with 39%RH inside and I'm definitely getting a bit of fog and ice on mine. Unless your windows were $1 Trillion and your actual RH is down to about 25%, you're going to get fog.
    *Note that my wall PoS is saying 30% and it's actually 39%, so that's why I question the controller accuracy.
    Also, some condensation isn't the end of the world. Very normal on windows that don't have much airflow or any behind closed blinds. No biggie.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    The windows are garbage. Upstairs we want to get them replaced with triple pane but theres a glass shortage and its $$$. The nest gauge is saying its 38% humidity, the humidifier is set to 20% it shouldnt be going at all i would think.
    Do you have an HRV? That will help to lower your humidity if it's on during extreme cold.
    (Heat Recovery Ventilator)
    V8s
    Zero chance that 20% is causing that much condensation at relatively mild outside temps like we're currently having. Turn it down until you are getting a manageable amount. You can get a more accurate means of measuring humidity, but that isn't required; it's more a matter of curiosity.
    edit: 38% seems more realistic based on what you said.
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Didn't see it mentioned yet so I'll say it: humidifier isn't the only source of humidity in the home. Cooking, showers, open toilets, plants are all sources as well. Breathing also contributes marginally as well, so try not to breathe as much.
    If you're really that concerned, open a window or get a dehumidifier.
    Only 15min from Aspen!
    Nothing interesting anymore
    Have you been outside the last two days? It's -23° right now. 20% will definitely give you condensation with old shitty windows.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    I would note that the condensation isn't freezing on the inside of the my windows its just wet. I just went and wiped down all the windows in the downstairs as this problem was very common when I lived in New Zealand. Unsure if it helps. I turned the humidifer off for now - if its reading the nest right it shouldnt be on at all.
    The SHBARUS
    The cheapo humidistat is highly inaccurate. 20%RH is unlikely. The lowest I had was about 25% with my humidifier off. You'll need a dehumidifier to go lower. I imagine you'll be walking around shooting out lightning bolts like Palpatine.
    If your house is at 20C and your RH is about 30%, the dew point is 2C. Anywhere on your window at lower than 2C you'll have condensation. Colder than 0C you'll have frost/ice.
    Sep 2012
    I cannot get the humidity below 32% in my house. If you have wood floors they hold a tremendous amount of moisture.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Does the MIL have an indoor pond/fountain?
    Sep 2012
    Quote Originally Posted by ercchry View Post
    Sure, in bed.
    Greasssssy
    sure, in bed.
    greasssssy
    lol.
    May 2004
    Ford, Acura
    Sure, in bed.
    You must spread some Reputation around before giving it to suntan (and nzwasp's MIL) again
    I'm generally cute.
    V8s
    Not really actually, I had no idea it was that cold
    Keep in mind, he lives in Aspen. It's not a 1950's build with original windows, they're "shitty" for a ~10 year old house.
    In my 50’s bungalow the ice on the windows just adds insulation value and free privacy glass.
  1. Headlight condensation in Lexus RX
    By 01RedDX in forum Car Care, Detailing and Body Work
    Latest Threads: 06-18-2009, 01:35 PM
  2. Condensation in my headlights
    By Kozikman in forum Car Care, Detailing and Body Work
    Latest Threads: 05-21-2009, 10:26 PM
  3. Headlight Condensation
    By BigBearWest in forum Mechanical
    Latest Threads: 03-08-2007, 08:19 AM
  4. F*#@ing condensation
    By funkedelic in forum Alberta BMW Owners Club
    Latest Threads: 11-14-2006, 10:48 AM
  5. Getting Rid Of Condensation
    By 2K255HP in forum Mechanical
    Latest Threads: 02-05-2003, 10:25 PM
