Float Valve - Boiler Piping - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: Float Valve - Boiler Piping
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Default Float Valve - Boiler Piping
    Anyone ever dealt with these? Watts FV4 to be exact. Just replaced them cause they were both passing liquid (suction and discharge) and the one on the suction is still doing it. I’m thinking the way it’s piped in isn’t letting the air and fluid seperate enough, any plumbers have any insight on this? Or any regular DIY guys ever felt with them?
    Sep 2014
    Airdrie
    Did you unscrew the black knob a few turns?
    Sep 2008
    NE
    Quote Originally Posted by tcon View Post
    ya they were open on the old ones and i opened them on this one too.. the liquid should come up and shut the float though. i think the dinky nipple and Tee aren't letting it work right or something. the other side comes right off the reducing tee then valve and it seems to not be letting as much liquid pass but still a tiny bit.
    I've got one of these on my hydronic setup but don't have the issues that you talk about. I did however just read the manual and you should have a fitting 2.5x the pipe diameter in order to vent air properly. Your suspicions about the fittings being too small seems to be pretty accurate. Prob same sheet you get with the unit but look at the install instructions.
    https://www.watts.com/dfsmedia/0533d.../es-fv-4m1-pdf
  1. I want my boiler inspected
    By Buster in forum Home and Garden
    Latest Threads: 09-08-2016, 11:43 PM
  2. Bradford white - Electric Boiler parts?
    By Kobe in forum Home and Garden
    Latest Threads: 11-10-2014, 02:54 PM
  3. FS: 3"x12' Aluminum piping, and 3"x6' 304 Stainless piping
    By 94_S14 in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 04-01-2012, 07:28 PM
  4. LF :: NEW Boiler Part - Honeywell Aquastat
    By syscal in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-28-2008, 07:55 AM
  5. Does anyone here have a boiler heating system?
    By Weapon_R in forum General
    Latest Threads: 11-12-2005, 02:58 PM
