Convince me to spend money: “new” car edition - Page 12 - Beyond.ca - Car Forums
Page 12 of 17 FirstFirst ... 2 11 12 13 ... LastLast
Results 221 to 240 of 335
Thread: Convince me to spend money: “new” car edition
  1. #221
    Beaumont
    Touareg, Cayenne, 944s
    Which vacuum line was toast? Is it the line to the wastegate? I'm glad you ripped into it, it will be worth fixing it.
  2. #222
    X5D, Fiesta ST
    Quote Originally Posted by JustinL View Post
    It was a hard line from the vacuum block to the small turbo that used a banjo bolt to seal to the small turbo. The banjo bolt was literally just finger tight and soot everywhere. Based on that and the exhaust manifold gaskets leaking (front 3 nuts were not tight) someone must have been in here before even though I have no history of it.
  3. #223
    Beaumont
    I'm no expert on BMW plumbing or diesel plumbing... or even the symptoms you were having... BUT wastegates are tough little suckers and I think it's more likely that the signal to the wastegate was the problem and not the wastegate itself. Put some psi from a compressor into the wastegate actuator line and see if it opens. A good cleaning and new gaskets and crush washers all around might be what you need. Check the parts the best you can before shipping them out for a more expensive diagnosis.
  4. #224
    Chevy Colorado ZR2
    @Twin_Cam_Turbo , Thinking of placing the '14 X5 for sale in early spring. It is not an M Sport BMW but it checks many boxes:
    -One owner, no accidents (some door dings, some rock chips on original windshield)
    -Reliable N55 (full service records history, only oil changes, and cabin filter changes)
    -Balance of Factory Extended Warranty until 100KM or Dec. 2022 (credit 1,000$ at the end of a warranty)
    -Optional 7 seats
    -M Performance Power Pack Kit (320hp 320tq)
    -21" M Performance forged wheels 599M, tires 90%, no scratches or scrapes.
    -Invisihitch 2" hitch and hidden receiver (used for bicycles only, no wiring harness for towing)
    -85,000 km
    -18" winters Blizzak from tirebob
  5. #225
    X5D, Fiesta ST
    Quote Originally Posted by jaylo View Post
    -Optional 7 seats
    -85,000 km
    Thanks but X5 is just too large for us.
  6. #226
    Chevy Colorado ZR2
    Quote Originally Posted by Twin_Cam_Turbo View Post
    As a BMW fan, there is definitely better driver feel and comfort in the X5 vs the X3 when I test drove them, but I get what you mean by the size.
    In today's standards, the X5 seems small compared to the new crossovers like the Palisade, Atlas, etc...
  7. #227
    My X5 is a very pleasant size for what you get.
  8. #228
    X5D, Fiesta ST
    Bump fixed my BMW and the turbo Alamo rebuilt 1700km ago has failed catastrophically this time.
  9. #229
    V8s
    That blows.
  10. #230
    Dec 2005
    not calgary
    changes every year
    God damn. Hopefully there is a warranty.
  11. #231
    Are these turbos particularly bad or something?
    I know BMW’s are expensive to fix but they typically aren’t straight up unreliable so it sounds to me like a shitty job on the turbo rebuild / a turbo that was too far gone to be rebuilt?
    That or an underlying undiagnosed issue that’s frying your turbos?
  12. #232
    X5D, Fiesta ST
    I posted in another thread months back but the turbo didn’t even need to be rebuilt, the actual issue was an exhaust restriction that both shops missed and I eventually found. They rebuilt it without authorization and it’s likely failed because they messed up the rebuild it didn’t even need. So far I’m about $2500 into this bullshit rebuild that I didn’t even need in the first place but now the turbo is totally failed leaving me in an even worse position.
  13. #233
    Gotcha. Wasn’t aware of that context. That sucks.
  14. #234
    Feb 2020
    Edmonton
    My understanding is a lot of turbo "rebuilds" are bogus nowadays. Modern oem design turbos have features which don't lend themselves well to rebuilding/remanufacturing.
    Ran into that with an LML. No specific comment on BMW's.
    If I had known you guys would end up being such bitches, I would’ve opened the parenting forum.
  15. #235
    X5D, Fiesta ST
    https://youtu.be/bOZ6YTeZgoo
    This is what the turbo looks like now.
  16. #236
    Oct 2003
    ute
    uh, this is simply not true.
    BWMs have had many generations of catastrophic design flaws across a range of engines.
  17. #237
    Manufacturer reliability rankings and statistics suggest otherwise
  18. #238
    Feb 2020
    Edmonton
    The old n/a engines (except for S54 which ate bearings every 30k kms lol) were all stout for sure, those are still available in some models.
    Even the turbo 4 is pretty reliable. But the turbo sixes have been hot garbage for a long while (not the engine itself, but auxiliary issues like turbos and high pressure pumps).
    I cannot comment specifically on the diesel.
    Also surely manufacturer reliability ratings never lie, and we all know 60% of the time stats are 100% correct.
  19. #239
    N54 was problematic for the reasons you describe, but they are 2-3 engine generations later from that 6. They were phasing that engine out in 2012.
    N55 and B58 have been very stout.
    And I refer to rankings of manufacturers, not data from the manufacturers themselves. People whining about blowing up their engines with JB4’s on the internet aren’t exactly the most representative data source on the planet either.
    Probably the worst thing lately is the blown V8’s burning oil. But that’s not really a dead on side of road issue.
  20. #240
    Jul 2008
    North North Dakota
    Nissan x2
    Our now sold X1 (2018) got to 100k without a single issue. Combined 100k between two E90s with S65s and no issues, on stock bearings. Just need to buy the right engines, everything else seems pretty reliable as far as electrics go.
  1. Buying a car from Quebec - convince me not to
    By Superman403 in forum General Car/Bike Talk
    Latest Threads: 01-17-2015, 08:59 PM
  2. someone convince me not to get this exhaust.
    By rith in forum Performance Modifications
    Latest Threads: 06-23-2006, 01:17 PM
  3. Replies: 17
    Latest Threads: 11-18-2004, 12:18 AM
  4. Newbie @ Cars <--- Money to spend.
    By dj_echo in forum General Car/Bike Talk
    Latest Threads: 03-16-2004, 09:13 PM
  5. How to convince your parents to...
    By 403Gemini in forum General Car/Bike Talk
    Latest Threads: 10-16-2003, 06:27 PM
