Lipstick on a Pig - Page 2 - Beyond.ca - Car Forums
Page 2 of 8 FirstFirst 1 2 3 ... LastLast
Results 21 to 40 of 142
Thread: Lipstick on a Pig
  1. #21
    Cochrane, AB
    Trucks
    That should be the Police Interceptor package. Mad max style.
  2. #22
    Sep 2008
    Turbo stuff
    Heat wrapped my downpipe and installed it for good
    Built a quick "muscle car style" (aka lazy fuck style) exhaust that dumps in front of the axle. If this is unbearable I'll build a tailpipe out to the bumper with a glasspack or something.
    Did a bunch of cutting in the nose of this and was able to stuff my intercooler above the frame rails and behind the grille just like I wanted. A plastic trim panel covers it and the rad support up top.
    It is a bit obvious. If the grille is easy to remove I may give the intercooler a quick black spraybomb to hide it a bit better.
  3. #23
    Aug 2011
    Strathmore
    2005 Dirtymax
    You should be painting some bright red or pink to stick with the lipstick theme
  4. #24
    Aug 2002
    992 T-hawk Golf R
    I like that you at least take the time to run the exhaust towards the back of the car. I know it’s very popular to exit turbo exhaust somewhere at the front or out the hood, but I can’t see how that isn’t really bad for fumes, when cruising with a window down.
    Edit: +1 for painting the intercooler black
    I like neat cars.
  5. #25
    Sep 2008
    Turbo stuff
    Turbos love short exhausts. But I think if you're under 500whp there's no reason to do a hood/fender/bumper exit besides laziness. You aren't giving up much power, if any.
  6. #26
    Mar 2007
    Edmonton area
    Has wheels
    Awesome progress, that pig is going to be fun to play around with.
  7. #27
    Dec 2005
    not calgary
    changes every year
    Looking killer.
  8. #28
    6.7 CUMMINS, E50 AMG
    I see you still have your plasma table! (I came to look at it) I bought a new ShopSabre 5x10 w/ Powermax 105. Let me know if you want a control retrofit, could be a nice machine!
  9. #29
    Sep 2008
    Turbo stuff
    Yeah we are too insanely busy for me to have a day with it to get it up and running lol.
  10. #30
    Dec 2008
    Unit 91 come in 91
    I love the intercooler the way it is behind the grille.
  11. #31
    May 2008
    Quote Originally Posted by Shlade View Post
    I second this. Cool project!
  12. #32
    Sep 2008
    Turbo stuff
    Decided to finish my exhaust out to the bumper, had an extra V band I already paid for anyway.
    Built a good proper cold air intake for the turbo, and built my hotside intercooler pipe.
    Built my cold side bumper pipe, a little rusty on the aluminum tig... but better than a lot of guys I see call themselves fabricators lol.
    Ended up having to chop that since it didn't want to install as one piece, too tight. I try to build intercooler kits with as few pieces as possible, since a weld is a better joint than a silicone coupler, but you gotta do what you gotta do.
    And all done up top with MAF flange welded on. Just missing a 45 degree coupler I'll get for next weekend.
  13. #33
    Jan 2022
    2019 Peterbilt
    Nice work.
  14. #34
    Sep 2008
    Turbo stuff
    Installed injectors today
    And re mounted ABS and PCM
    Just did a little testing around the block and the stock MAF will absolutely not cut it, so ordered a HPX MAF which should support plenty of power in this setup. Can start hitting some boost when that arrives.
  15. #35
    Sep 2008
    Turbo stuff
    Installed wideband and boost gauge today. I like to make my own gauge cups out of stainless, low profile so it can hug the column unlike the bulky plastic cups that usually come with gauges.
  16. #36
    Dec 2008
    Unit 91 come in 91
    That looks great
  17. #37
    Mar 2007
    Edmonton area
    Has wheels
    Great work as always with your projects.
    If I was still in the Calgary area, I'd be looking for help with my project
  18. #38
    Sep 2008
    Turbo stuff
    Assembled the bomb tonight. It's an 034 Motorsport surge tank with an oldschool Bosch 044 inside it. I'd never go this route these days, but I bought this literally 10 years ago for my Aristo and never used it because the stock pump was enough on that car. Every other car I just stick an intank walbro in it.
  19. #39
    Sep 2008
    Turbo stuff
    Found some little presents in the windshield cowl. These are casings from simunition training ammo.
    Mounted and wired the fuel surge tank. I'll build some fuel lines next weekend.
    Installed the VMP MAF sensor.
    Threw a resonator into the tailpipe just to take the edge off the exhaust note while cruising.
    And some pre-boost maintenance. Colder plugs, oil change, and a fuel filter. Lots of people overlook the fuel filter when modifying a car and then scratch their heads why their car keeps going lean when it hits boost. At higher mileage they can get pretty plugged up with sediments, etc.
    Hit a little boost today and had to test if it improved its burnout ability.
    And that's how you build a turbo car in one short month.
  20. #40
    I can't rep you right now.
    But you're officially my favourite beyonder.
  1. Whole Pig - Pig Roast
    By TheCheff in forum Food and Dining
    Latest Threads: 08-06-2018, 08:19 AM
  2. How to get lipstick off shirt?
    By GTS Jeff in forum General
    Latest Threads: 08-18-2006, 12:09 AM
  3. Lipstick (lmao)
    By gorillam in forum Misc. Gallery
    Latest Threads: 01-03-2005, 11:06 PM
  4. Weighed the pig last night
    By HillBilly in forum Bike Talk
    Latest Threads: 10-02-2003, 11:34 PM
