Pheoxs' Garage/Workshop Build thread - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 32 of 32
Thread: Pheoxs' Garage/Workshop Build thread
  1. #21
    Elbonia
    Jeep of Theseus
    Any reason to run that over regular cat 6 if its in a conduit? Or just one of those it's only a couple bucks more so why not situations?
    For the same reason you can't (by code) run NMD90 in buried conduit - even cemented PVC conduit isn't considered watertight. For the minor cost increase it's worth using the right stuff - I think my pair of 100ft cables were a total of $80.
    I put my ethernet conduit in the same trench as the gas line.
  2. #22
    Jan 2017
    Summer car or work truck
    The power and communication can go in the same trench. Just not the same conduit. If the duct has 4 inches of separation, between power/comm, that's better than 99% of residential installs out there. Guaranteed.
  3. #23
    Mar 2010
    Ioniq 5
    Good to know, thanks!
  4. #24
    Mar 2010
    Ioniq 5
    So a few updates:
    - Star building quoted me 13.5k for the building package which is high but seems reasonable for the current supply chain issues. I called a few places pricing out stuff like the garage door, man door, windows, etc and all the pricing seems consistent unfortunately.
    - Impact Concrete got back to me and quoted 24k (!) for the garage pad, which isn't happening. Rolling mix took my info, called me to ask a few questions then hasn't got back to me yet.
    I did have a question about insulation, for the scissor trusses it seems the easiest way is to pay someone to spray foam the ceiling but from what I've read if I go that route I -don't- want any ventilation in that portion of the roof correct? If that's the case then would it just be spray foam the inside of the sheathing, then throw up drywall on the bottom of the trusses. Do I need some kind of attic hatch on that side still incase of leaks or what not?
    Adding to that I guess, if there is no roof vents that means I use non-vented soffit as well correct?
    Edit: Or I think I'm misunderstanding and should use vented soffit, some vent baffles along the length of the roof to the top and then still have vents at the top? I keep finding different info but not all of it applies to our cold climate
  5. #25
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Just here to plug Infinite Cables for your bulk ethernet needs. +1 for direct burial inside conduit, threw mine in the gas trench as well.
  6. #26
    So a few updates:
    Here's my 2¢ but maybe 1.5¢ because I start to get confused with spray foaming ceilings or roofs...
    If you're spraying foam on the bottom of the roof sheathing, that means you are extending the "living space" envelope all the way to that surface. That means you want that area to be ~as warm as the area you normally occupy. So, that tells me zero roof vents and to not use ventilated soffits. Sounds rational, right? I'm happy to be proven wrong by someone more experienced in this.
    In a house, you are required to put drywall over spray foam to provide a small fire barrier as it is flammable like gasoline. Barring that, you have to use this other blown-on shit (such as in rim joist cavities) to "protect" from fire. There is a tiny chance that you would not be required to do this in a garage... I don't know if the code varies for a space where people don't sleep. But you still should because it's crazy-flammable.
    Note that it's about $4/sq-ft so do some mArTh now and realize how incredibly expensive this will be, plus your Op-Costs go up (somewhat) because you're heating WAY more airspace.
    Now, let's tackle spray foam on the attic side of the ceiling. Is what's in my skull bucket coming out onto these words? Your garage has a ceiling with an attic hatch in it and on the other side of that ceiling/drywall (on the "attic side") is spray foam. This strategy indicates you want the occupied space to be warm and you don't give a shit about the attic, so you need it to be as close to the outside temp as possible by having roof vents and ventilated soffit. Sound rational? Again - someone else chime in if I'm talking crazy. This will be WAY cheaper as the sq-ft to spray foam will be some pythagorean-ratio of way-the-fuck-less. Plus, you MIGHT not have to put fire barrier on it and you're not wasting energy heating your attic.
    Hope this helps.
  7. #27
    Jan 2017
    So a few updates:
    I spray foamed the roof where the scissor trusses are because I didn't really know how to insulate otherwise. If spray foam is what you do, directly on the roof, you don't need a vented soffit, or roof vents. It also won't matter of they are vented, the just block them and foam as normal. I have vented soffit and roof vents because I didn't know what I was planning until everything was built. No big deal, and gives you either option. If you spray foam, it needs to have a fire barrier. Paint or drywall. I think drywall needs to be 5/8 to be a fire barrier.no attic hatch would be needed because it would be conditioned space. Plus there would be hardly any space between the bottom of the scissor truss and the spray foam. You can pop by to check it out of you want. Might help to see it in person.
  8. #28
    Mar 2010
    Ioniq 5
    If you don’t mind I’ll take you up on that sometime. Do you know how much they insulated your roof? I’ve been reading if it isn’t R40 that I may run into issues of moisture in the sheathing though being there’s a membrane barrier I don’t understand how that’s a thing.
    If you drywall over the bottom of the scissor trusses does that not close in the attic space a bit? The drywall being a barrier between the conditioned space and the inside of the trusses?
  9. #29
    Feb 2004
    G35
    Hey check out Spray Jones vid's on youtube and reach out to them if you still have questions.
  10. #30
    That's not moisture from the outside. It's another version of "attic rain". The warm moist air from the living space will condense on a cold surface and since the exterior of the roof could be -35°C then it will take a great deal of insulation to keep the living space side above the dew point of the house air. I'm not sure that the magic # is R40, but it's going to be a big number.
    Over the thickness of only 4.5" or 6" you've got -35°C on one side and +20°C on the other. So that's a 55° delta which is asking a lot. Again, I bet that just made it $7/sq-ft instead of "only" $4.
    It's so awesome... But $$$...$$$$
  11. #31
    Jan 2017
    Looks like I only did 4 inches of foam. R25 ish on the roof. I suppose you could get some moisture trapped between the drywall and spray foam? That's why I just painted the foam. Both above and below are within the conditioned envelope?? I'm not sure.
  12. #32
    Jan 2017
  1. Replies: 87
  2. For Rent: Heated/Water Detach Oversize Double Garage/Workshop (Cranston)
    By yohan4ws in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-21-2011, 11:26 AM
  3. Wanted: Double garage for workshop, 220v
    By JungleMatic86 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-10-2009, 04:13 PM
  4. WTB: 1986 Hyundai Stellar workshop manual
    By Arthur Dent in forum Automotive Parts
    Latest Threads: 06-22-2005, 04:05 PM
