Why is my epoxy floor chipping? - Beyond.ca - Car Forums
Results 1 to 20 of 24
Thread: Why is my epoxy floor chipping?
    Nov 2005
    2015 Hyundai Veloster
    Default Why is my epoxy floor chipping?
    I just moved into this house and one of the things I liked is the really nice epoxy floor in the garage. For some reason the previous owner didn't put any drainage in the floor so I just recently noticed all of the snow melts off my car and then pools on the floor and gets soaked up by the walls. I started shovelling the water out the door and now I notice big chunks of the floor coming out, is this normal? Or is it a hack job by the previous owner just prior to sale?
    Also, is this something that would get covered under some kind of warranty or insurance?
    Originally posted by Go4Long
    Originally posted by blitz
    This is likely a DIY kit from Home Depot and likely not done well.
    Get another kit, strip it down, properly prep the surface and away you go!
    Feb 2003
    DT 780
    LEXUS LX470
    Hard to tell from those pics but it almost appears like it is the concrete itself spalling and failing with the expoxy going along with it
    Tap, Rack, BANG!
    Jul 2008
    Edmonton, Alberta
    Probably poor/non existent prep work of the concrete for the epoxy. If you can find out who installed it, they may warranty it, but likely DIY.
    X5D, Fiesta ST
    They must have Marth’d the mixture.
    Feb 2020
    Aspen Ne
    Hack job, will get much worse over the next few years. If moisture is being “soaked” up by the walls, enjoy the black mold.
    Looks like a frozen, dead battery was stored there, at some point...
    Better move.
    '14 Taco
    But what happened to the veloster?
    Feb 2007
    1991 Toyota Soarer
    Looks a mixture of poor prep work and spalling that was not addressed during prep. Water might be getting under it and freezing causing it to lift.
    I just bought a place to fix for a year or two then flip and I had my garage done with quartz epoxy and added a ton of flakes so it is not going to the kill kids in the winter, some epoxy floors are so slippery. We had cracks and spalling all over the place. We do a ton of Epoxy at work now and it takes 2 days to complete with a new floor. Mine took nearly 12 days due to prep and dry time. I had them grind done nearly 1/4" off the whole floor to remove ant spalling and open up the cracks to properly fill. After that we did seven coats of epoxy to prevent any issues in the future. My epoxy guy was like, man this is crazy we do less work in airplane hangers of commercial auto shops lol
    But once my stuff goes in the garage I will never have a chance again to do it or even repair it. one day I will post a Reno thread but my 1-2 year Reno should be completed in 3 months, so now I can relax
    Feb 2003
    DT 780
    LEXUS LX470
    Wow that looks sick
    Tap, Rack, BANG!
    Nov 2005
    Quote Originally Posted by gyromonkey View Post
    I just bought a place to fix for a year or two then flip and I had my garage done with quartz epoxy and added a ton of flakes so it is not going to the kids in the winter, some of it is so slippery. We had cracks and spalling all over the place. We do a ton of Epoxy at work now and it takes 2 days to complete with a new floor. Mine took nearly 12 days due to prep and dry time. I had them grind done nearly 1/4" off the whole floor to remove ant spalling and open up the cracks to properly fill. After that we did seven coats of epoxy to prevent any issues in the future. My epoxy guy was like, man this is crazy we do less work in airplane hangers of commercial auto shops lol
    You didn't put in a drain neither. What are you going to do with snow melting off your vehicles?
    Feb 2007
    1991 Toyota Soarer
    Wow that looks sick
    Thanks man, its coming along, My Hexagrid lighting just arrived today and flooring should arrive Friday for the garage ceiling then I get the fun task of installing it after I paint the garage. we added a sub panel and 14 plugs and 14 pot lights on the upper had of the garage.
    not to thread jack
    not my cars in the photos
    Feb 2007
    1991 Toyota Soarer
    Quote Originally Posted by Mar View Post
    As bad as it sounds I don't drive my car or trucks in the winter, I typically drive my work truck and it stays outside, the garage is more for my toys.
    If was building new I would for sure add a drain, but with this being a temp house for a year or two I don't think the cost and work would add enough value for the headaches of digging on in and sloping the garage floors etc etc
    Real car guys don't park their daily in the garage. Get in the game!
    We let the neighbourhood scum check our daily driver's door handles and try to steal those.
    Mar 2009
    '18 Murano
    Whats wrong with water on the floor? I dont have a drain in mine and what usually ends up happening is that the heater just evaporates the water by the time I return to the garage the next morning.
    Nov 2005
    Quote Originally Posted by A2VR6 View Post
    It pools around certain areas, mostly around the walls. The wooden shelving soaks it up and I'm guessing the drywall does too. Plus the tires of my other car would be sitting in standing water constantly and it likes to make its way over to the CTEK charger which I used to leave on the floor. I have the heaters set to 11 degrees so it doesn't have a chance to evaporate by the following day.
    I did pick up a mat specifically for this which Porsche had in their display area so that problem is sort of solved now since all of the water collects on the mat but I'm still wondering if the floor is just going to completely crumble away.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Looking at how rough the surface looks under that epoxy it doesn't even look smooth or like a great surface.
    So I would bet more is going to lift on due time.
    A garage floor mat will keep the water from pooling at the walls. They are unreasonably expensive, so here is a cheaper, somewhat absorbent one:
    https://www.amazon.ca/Armor-All-AAGF.../dp/B00HQOQCY6
  1. Garage epoxy floor DIY
    By craigcd in forum Home and Garden
    Latest Threads: 11-02-2018, 02:36 PM
  2. Need a pint of epoxy sealer
    By Modelexis in forum Car Care, Detailing and Body Work
    Latest Threads: 04-20-2011, 07:06 PM
  3. Garage floor - epoxy paints
    By 89coupe in forum Home and Garden
    Latest Threads: 03-03-2011, 11:08 AM
  4. epoxy hardener for CF available locally???
    By riceeater in forum Performance Modifications
    Latest Threads: 11-24-2005, 04:15 PM
  5. Best places good local places to get Epoxy/resin in Calgary.
    By shadow in forum Cosmetic and Styling Modifications
    Latest Threads: 09-13-2004, 11:42 AM
