Changing oil by extracting from the top? - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Changing oil by extracting from the top?
    Jun 2020
    Airdrie
    Default Changing oil by extracting from the top?
    I'm going to maybe sound like an idiot here...do any Beyonders use something like this to change the oil in their cars?
    https://www.amazon.ca/Powerbuilt-647...058853&sr=8-17
    I've always done it from the bottom, never even thought about this...how effective is it at getting all the oil out?
    Is there a cheaper contraption I could use? As for the filter, it's a Bimmer so it's changed from the top.
    Thaco's Avatar
    Oct 2004
    Rage2
    Quote Originally Posted by JohnnyHockey13 View Post
    most oil pans have baffles and stuff in them to keep oil in the pickup tube area, i wouldn't think this would work (well) unless the engine is intended to use an extractor.
    User title molested by Rage2.
    ^^ Fact Checked
    This is not my favourite idea, but
    Jun 2020
    Airdrie
    Darn, guess I'll do it the ol fashion way then.
    isn't this procedure standard on some engines? Mini or Smart or something?
    I know that equipment rental companies like United and Sunbelt have many of their rigs equipped to change oil on the fly, without draining. For things like Light Plants or Herman Nelsons, etc.
    But I think they have actually drilled & tapped fittings and hoses on their own.
    Sep 2008
    Turbo stuff
    Yeah Smarts have no drain plugs and have to be sucked out.
    Feb 2003
    DT 780
    LEXUS LX470
    The only thing I would add to this discussion is that if you are intending to remove contaminants from an engine/oil by extracting from the top, I personally would insert one additional step. I would extract all of the oil, add additional oil, and then extract again to try and dilute the remaining contaminants in the added oil and get those out as well. But potentially involves adding enough oil to actually run the engine before the second extraction.
    Tap, Rack, BANG!
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Mr lube are using these extractor machines now.
    That really does tell you all you need to know
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Would be a hell of a trick to use something that pumps via dipstick on a car without a dipstick!
    The old tale with JDM cars though is that they’re all full of sludge cause this is standard practice in Japan
    Jul 2008
    Edmonton, Alberta
    This seems complicated and pointless. Engines have been fine with the small amounts left in them doing it the conventional way, flushing it like this is a waste of money and time.
    If you change your oil often enough none of this is a problem.
    Jul 2008
    Transnistria
    Exploded.
    I do it frequently and use an extractor pump from the dipstick, primarily because the oil pan on the S3 is plastic with a plastic plug.
    calgary ab
    4x4
    the why - it's cleaner... Which of us hasn't slopped or spilled the drain tray - going straight into final storage is awesome.
    If you don't have to crawl under your car for an oilchange why would you?
    Sep 2005
    I bought a pneumatic one because I thought it was a great idea.
    https://www.canadiantire.ca/en/pdp/m...?rrec=true#spc
    What Thaco said is true.
    Turned it it wasn't great and didn't end up saving much time so I do it the old fashioned way.
    I keep it for other fluid changes though.
    Mar 2005
    Foothills County
    is faster than yours
    Quote Originally Posted by AndyL View Post
    Why wouldn’t you just use your lift and extendible oil drain container? It’s super easy!
    Feb 2003
    DT 780
    LEXUS LX470
    Quote Originally Posted by ShermanEF9 View Post
    I agree. Its stupid. Drain from the bottom like a real he/her man.
    Tap, Rack, BANG!
    Mr. Lube to offer oil pan gasket change and flush soon?
    V167
    Do it all the time on the diesels in our family. Use the one from princess auto.
  1. extracting caption from video?
    By davechoi1973 in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-26-2008, 01:49 AM
  2. Extracting a file from an .EXE
    By Zero102 in forum Computers, Consoles, and other Electronics
    Latest Threads: 12-27-2007, 11:32 PM
  3. Extracting DYNOJET data
    By speedracer in forum Mechanical
    Latest Threads: 03-15-2007, 11:36 PM
  4. Extracting a video from a site
    By iceburns288 in forum General
    Latest Threads: 11-07-2005, 12:55 AM
