DSM Guys - Wipers - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: DSM Guys - Wipers
    Sep 2002
    Default DSM Guys - Wipers
    Ok, so some of you are aware of my wiper problem (not having intermittent setting on the front wipers, and not having anything happen in the back end at all).
    So today I attempted to tackle the rear motor, its easily accessible and only 3 screws to get to it.
    Anyways I opened her up and saw initially that the power connector was not attached. Thinking how easy it was to fix I was quite happy. I got into the car and started it up, tried the back wiper, nothing, tried the front wipers nothing. Blown fuse...
    So I disconnected the rear motor again, and put in another 20A fuse and started up the car, the front wipers worked (with no intermittent setting) again. So I tried everything again with this new fuse and connected the rear wiper motor to power again. Right way when I start the engine (possibly when I flip either wiper switch) the fuse blows again...............
    So I have the rear motor disconnected again and a new 20A fuse in the box. The front works as before.
    Is there any suggestions, has anyone encountered this before.
    I copied down the name and part number on the Wiper Motor. Maybe one of you guys can check to see if its the right one for me.
    I can tell that mine is a new motor, due to how clean it looks, but it may be the wrong one?
    It is a:
    Denso 159100-9833
    12Volt
    12P
    Thanks guys,
    David
    '07 Ranger FX4 Level II
    Dave, i suggest that you check to see if the short is in the actual motor or if its in the wiring. take the motor out and hook it up directly to your battery and see if it works. if it does problem will most likey be the wiper control switch (dont know if your talon has one but my truck does.. both dsm) or be super lazy hook it up to your brake lite.. so when you need to use the rear wiper just tap on your brake ... as for the intermident wipers.. could not tell you whats wrong
    Originally posted by rage2
    Sep 2002
    HAHAHHAHAHAHAHA That is hilarious Rob, Could you imagine, every time I was at a light, and if I had my foot on the brake my wipers would go .... Hahahahahhaah! You coming out tomorow?
    yep ill be there
    Oct 2002
    Moose Jaw
    2004 Mitsubishi Lancer Ralliart
    Yeah pull the motor off and test it seperate. It isn't too likely the wiring from the car to the wiper is shorting or you'd be blowing that fuse all the time.
    Aug 2002
    I'm thinking it was the previous owner who unplugged it... because everytime he hit the switch this fuse would blow and...
  1. Sticking up the wipers...
    By Heep in forum General Car/Bike Talk
    Latest Threads: 08-06-2003, 08:28 AM
  2. Attn: TurboDSM and DSM Guys!
    By Dope Dealer in forum General
    Latest Threads: 11-05-2002, 06:24 PM
  3. question for any dsm guys our there
    By LUDELVR in forum Performance Modifications
    Latest Threads: 08-15-2002, 08:50 PM
  4. Guys I need your guys opinion..
    By lammer in forum General Car/Bike Talk
    Latest Threads: 08-12-2002, 08:46 AM
  5. Who wants to watch a 13.0sec dsm get 0wned??
    By CRXguy in forum Cars, Bikes, Machines
    Latest Threads: 06-04-2002, 12:50 PM
