any thoughts on what this fastener / threaded rod is called? - Beyond.ca - Car Forums
Results 1 to 20 of 22
Thread: any thoughts on what this fastener / threaded rod is called?
    Subaru Outback
    Default any thoughts on what this fastener / threaded rod is called?
    Trying to get an old motorcycle sorted out and this part just arrived after waiting for 8 months to get here from Italy. I would like to buy a backup (I should have ordered a few of them).
    One side had right handed threads, the other side is left handed. I believe they are M6 size.
    Anyone know if someone in Calgary might carry these in a hardened steel as it's a part of the shifter rod assembly and gets a decent amount of shear stress on it?
    I'm also wondering if I can simply get rod in a single direction thread, replace the one heim joint that it fits into with the same threaded female end and not worry about having the dual threaded rod. The purpose is so you can screw it one way or the other and that raises or lowers the shifter arm assembly.
    I've checked all the big hardware stores with no luck.
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    Looks like an adjustable tie rod of some sort. Function also matches as some sort of tie rod. Prob all the help I can be unfortunately.
    Instead of right and left hand threads, add a nut and lock washer on the threaded portion which will clamp the threaded joint in place. Should be able to avoid a right and left hand threaded parts.
    Could walk that part into Calgary Fasteners for some in-person advice.
    Sep 2005
    Rod end bearing
    Oct 2003
    ute
    ass to ass.
    May 2004
    There is a transmission supply place almost across the road from coco brooks off blackfoot trail that might carry that kind of thing
    calgary ab
    4x4
    Quote Originally Posted by lamp_shade_2000 View Post
    Transmission supply ltd - yup Andrea would probably take one look and be able to grab it off the shelf
    Jul 2008
    Edmonton, Alberta
    Dec 2006
    Nothing worth mentioning.
    Quote Originally Posted by ShermanEF9 View Post
    Just about to post this.
    Fuck yeah beyond, you dudes are helpful and smart and nice and awesome and smell great.
    Subaru Outback
    perfect, that looks like what I need. Doesn't look like they ship to Canada unless you are a business but I'll see if anyone carries these locally
    May 2004
    Ford, Acura
    I've had them ship to me before. Can't remember how I did it, but I don't really recall doing anything fancy. I do remember shipping be absurd though
    I'm generally cute.
    Mar 2015
    Toyota’s
    I've been able to find stuff like that on ebay before, it might have been Fastenal but their US ebay store will ship to Canada when the website doesn't
    Jul 2008
    Edmonton, Alberta
    Quote Originally Posted by Pacman View Post
    if anything it gives you an idea of what you're looking for.
    Looks like a toyota exhaust manifold stud.
    M10, though. Sorry. But close.
    http://www.koracing.net/viewproduct....=3&product=567
    Try acklands in Calgary.
    https://www.grainger.ca/category/Thr...ildCard=false#
    Subaru Outback
    Just to update, I've gone to every fastener store in Calgary with no luck. Someone suggested using a tap and die set, buying a piece of blank rod and creating my own threads, turn the die over and do the reverse threads on the other side. I've never done this before but sounds like a reasonable idea to try before I make an order with McMaster Carr and get hosed on shipping fees.
    Anyone have any experience doing this? Is it as easy at the youtube videos suggest?
    Jul 2008
    Edmonton, Alberta
    my only concern is the metal being soft enough to do that with, and it causing you issues down the road?
    Hold up!
    I think I've got the company. Never ordered from but this would work for you if you can confirm the thread pitch.
    https://belmetric.com/m6-double-ende...ass-5-8-steel/
    They've got length options and would be high grade steel.
    I'd almost contact them through email as I think this is what they specialize in out of USA.
    May 2009
    Medicine Hat AB
    General Motors Competizione
    All you want is the threaded rod in right and left hand thread? Get me the measurements, I'll make it in school and mail it to you.
    2007 GMC 2500 Duramax
    1981 GMC C1500 454
    Sep 2006
    Princess Auto has some in 1/4-28 RH if you can make that work at all. Otherwise I'd be looking at Speedway/Summit. Could also give Mopac a call. They have rod eyes, just not sure if they have the stud kind.
    Also, you can't 'turn the die over' and make reversed threads. A RH die makes RH threads no matter which way you start it. You'd need a LH die (or to cut the threads on a lathe).
    dv/dt
  1. 2014 Chevrolet Silverado factory running board fastener/bolt issues
    By TomcoPDR in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 03-20-2015, 01:37 PM
  2. 3jam threaded SMS
    By CMW403 in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-09-2010, 11:55 PM
  3. Where to buy threaded threadolet / bungs?
    By red99600 in forum General Car/Bike Talk
    Latest Threads: 06-22-2008, 05:22 PM
  4. Can't find anybody that sells reverse threaded screws! Help?
    By s3v3n in forum General Car/Bike Talk
    Latest Threads: 03-31-2007, 12:56 PM
