CAD file to materials list - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: CAD file to materials list
    Nov 2003
    Calgary / AB
    '13 MazdaSpeed 3, Zoom Zoom!
    Default CAD file to materials list
    Does anyone have software that can use dwg file to create a material estimate for lumber, joist, truss, sheeting, etc?
    Is this something Chief Architect does?
    My Karma ran over your Dogma
    Quote Originally Posted by cidley69 View Post
    I think this it's a missing link in much of the available software. I know people who wrote code to get these programs to more efficiently generate MTO's.
    If you can generate individual drawings, there could be a Bill Of Materials in the side of each drawing... I'm not sure.
    Nov 2003
    Calgary / AB
    It doesn't seem like it would be hard math for a computer.
    Sep 2003
    Defender, Allroad
    Do you have 2D or 3D .DWG's? You'll need 3D at a minimum. Can you post a couple of screens shots of what the files look like? I doubt any of the oil and gas software that a bunch of us are familiar with is going to be very helpful here. I suspect the software that generated the drawings is capable of generating the MTO's (but I'm assuming you don't want to pay for it?), so you'll need to do it by hand to get your quantities. Not hard math for a computer to do, but software vendors like to lock this functionality up in their ecosystem as a reason to buy their software.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Inventor does this, but the trick is you need to add the data for each part when it’s created initially
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Pretty well Every software does this, but in its own way… so it’s not as easy as opening a dwg and exporting an MTO.. has to have some sort of database or properties to export, and then has to have compatibility to export them.
    Even in Vanilla AutoCAD if the blocks have any attributes or individual names/layers/properties there is ways you could probably do it, but it would be super rudimentary and there would Be manual inputs and organization involved.
    But npham is right, realistically needs to be a 3D model. If it’s 2D and has blocks you could still do it but you’re setting yourself up for errors.. may as well just count by hand on a notepad haha
    I used to be able to do this in inventor.
    But the whole model needed to be built from the start using inventor’s parts catalogue.
    So if your drawing already exists you would need to start over.
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    Quote Originally Posted by JfuckinC View Post
    I could see this being done with a COUNT if each truss was a block reference for example. As in counting each block reference. But errors could include exploded blocks etc.
    Edit:
    Civil3D has a method of counting XREF instances. So if your drawing has each countable material as the same XREF then maybe???? Again, the potential for errors would abound.
    BCOUNT is the block reference count.
    missy
    Hmmmm…. Most cad softwares can do this with models… Since dwgs are just vectors, I’m not sure you can differentiate one from another. One way to do it would be to give each component a different colour. Then, filter / count line objects by filtered Colours and divide by the number of sides of said features. If I’m making any sense lol
    CNC Guru*
    Instagram: goreski_rdd
    Sep 2008
    NE
    Bunch of nerdy drafters wanna help and the guys ghosts us
    Nov 2003
    Calgary / AB
    Lots of different angles on it being mentioned. I'm hearing that it's not difficult for the software to do this, but this feature is locked behind a pay wall and most users have no need to pay the extra to access the feature. If with this feature enabled the cad has to be drawn correctly in first place to generate an accurate extract. Which my file likely was not.
    There are some work arounds but these may be more work than just doing it without the software.
    If cad file could put linear feet of interior and exterior walls, and sq ft of floor/roof, could use this info to make estimates of materials quantity.
    Feb 2008
    With a basic .dwg AutoCAD can extract line lengths and hatch areas. You could then export those to an excel file. It'll still take a bit of work to set everything up though.
  1. FS: OBD1 P06 ECU + Socket chipping materials
    By HK2NR in forum Automotive Parts [Engine Electronics]
    Latest Threads: 06-24-2006, 10:31 PM
  2. Amateur Question: Finding th Setup File in the installed program file folders
    By Mckenzie in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-28-2006, 07:32 AM
  3. Best CCNA exam prep materials?
    By Hollywood in forum Computers, Consoles, and other Electronics
    Latest Threads: 07-19-2005, 09:47 PM
  4. List Your Strength - List Your Weakness
    By hockeybronx in forum Health and Fitness
    Latest Threads: 03-11-2005, 09:12 PM
  5. Body work: materials? prep? what?
    By moojester in forum Cosmetic and Styling Modifications
    Latest Threads: 05-04-2004, 11:27 AM
