"Eh'ts for 8" Firebird Build - Page 3 - Beyond.ca - Car Forums
Page 3 of 4 FirstFirst ... 2 3 4 LastLast
Results 41 to 60 of 77
Thread: "Eh'ts for 8" Firebird Build
  1. #41
    Aug 2002
    992 T-hawk Golf R
    I was always concerned with a clear and defrosted windshield when cooler temperatures are inevitable.
    I suppose you could just use the sleeve of your hoody to wipe the fog though! haha
    I like neat cars.
  2. #42
    Mar 2007
    Edmonton area
    Has wheels
    Malibu had no heater core, got caught once where it was a bad time haha.
    Lemans kept its heat.
    Congrats on getting it together and moving! MoM should be a blast.
  3. #43
    Sep 2008
    Turbo stuff
    MoM starts Sunday? Ah, you still have enough time to bash a nitrous kit into it.
  4. #44
    Feb 2020
    Edmonton
    Quote Originally Posted by 90_Shelby View Post
    Rainx on the windshield, fogx on the inside. Ain't my first rodeo Tshirt on a stick is the fallback for inside fog, but can't get foggy inside with the t-tops down right?!
    Sentry, I am moving tomorrow in Edmonton, so I really only have today and Saturday. Gotta drive down to Medicine Hat Sunday and it'd be sweet to get a couple passes in. Rather have an issue there and call it versus getting halfway to Saskatoon on Monday afternoon.
    But yes, if my highway spin in about 45 minutes checks out, I may try to slap the turbski in.
    If I had known you guys would end up being such bitches, I would’ve opened the parenting forum.
  5. #45
    Saw this firebird and thought of this thread.
  6. #46
    Feb 2020
    Edmonton
    That one looks much nicer then mine, but I appreciate the thought
    Gah, the car gets hot on long drives. Might have to take donjuan up on his offer if I can't get anything else figured out.
    I didnt really "properly" bleed the system, could be a ton of air and I have no overflow which could have messed with things.
    I'm cutting the front bumper apart as the 4th gen is just a solid slab bumper beam, zero airflow through the entire bumper. Going to open the entire thing up.
    Have a bad vibration from 2000-2400 rpm. My dad says its missing, but I dont know why its smooth below and above that. I'm going to probably do the seppuku if the torque converter is shot as I specifically didn't put the other one in.
    I'm a pro at pulling the trans, but god damn transmission fluid, I hate it!
  7. #47
    Sep 2008
    Turbo stuff
    Weren't you planning to run it on E85? Start running it on it now and see if it runs cooler, I bet it will.
  8. #48
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    Quote Originally Posted by zechs View Post
    Its freeeeeeee
    Switching to E85 is almost guaranteed it will run cooler. Where do you get E85 here?
  9. #49
    Aug 2002
    992 T-hawk Golf R
    Could always run the heater on full blast to help cool the car.
    Oh wait......
    JK!!! JK!!!
    I like neat cars.
  10. #50
    Sep 2008
    Turbo stuff
    Its freeeeeeee
    Calgary has the one pump station at the 17ave souvlaki place, otherwise guys were buying barrels from VP or Fuse race fuels
  11. #51
    missy
    I solved my high temp issues by not running a temp gauge, it’s not the best solution but seems to work
    CNC Guru*
    Instagram: goreski_rdd
  12. #52
    I don't know domestics that well but there could be a good chance it's air locked in the rad or only using a partial rad.
    I'd use one of these types of kits and do a full warm up and cool down and see if you can get it to burp out.
    https://www.amazon.ca/ABN-Radiator-F...38068612&psc=1
  13. #53
    Feb 2020
    Edmonton
    Decapped injectors stuck open and flooded crankcase. Scrambled to find a new set, but idle psi was only 5psi when I noticed.
    Drained oil, just checking oil pressure with mechanical gauge and new oil. Swapping torque converter tonight if vibration at 2200rpm does'nt go away.
    It's thrash time baby!
  14. #54
    Feb 2020
    Edmonton
    Cold cranking pressure is 30psi with an oil change. Thank christ!
  15. #55
    Sep 2008
    Turbo stuff
    Fucks sake
    Did you buy the decaps or do them yourself?
  16. #56
    Feb 2020
    Edmonton
    I have an extra set of dual Altima fans if you want. They were too big for my car.
    Low 4.5 amp draw, high 7.5 amp draw +/- 10%. Low 974 cfm each, high is 1420 cfm per fan. I dunno if that's enough for your setup tho.
    @DonJuan you around? I need those fans lol
    Inhave a set of vr6 duals lined up but I like free.
  17. #57
    Feb 2020
    Edmonton
    Got a Genesis 3.8 fan, works great.
    Stabbed a hole in the rad because Im an idiot. Learned to aluminum braze today.
    Tons of other fiddly shit. Hit the road, ran out of fuel 5 minutes from home I think (did a pull, went super lean, pump doesn't sound right).
    Have 20L of fuel on the way lol
  18. #58
    Feb 2020
    Edmonton
    Definitely ran out of fuel.
    But now the drivers side bank of injectors doesn't seem to want to fire.
    Situation was:
    Cruising at 85km/h
    Pulled up to stop sign
    Did a decent pull 1st/2nd/lost fuel pressure and car started sputtering
    Pulled over
    Got fuel
    Buddy confirmed nadda coming out of bumper exit on driver side, lots of firepower coming out the passenger
    Reuploaded software, whack injectors with a crescent, raised fuel pressure, no dice
    Occassionally drivers side bank would come to life
    Finally towed it the 5 minutes home. Pulled first 2 plugs on driver's side, bone dry confirming no fuel (should be just hosed with fuel from all the cranking I'd think).
    Hail mary shot, I have two guys lined up (one in devon, one in millet). If I can get 4 injectors and swap them out, see what happens.
    No time for wiring diagnostic shenanigans, but all the grounds the terminator X requires are good. She's fed power directly from the battery as required, wiring is perfect.
    So unless the driver side bank of injector wiring harness got f'd somehow, I can't see the wiring being the problem. I have heard old injectors left in the air and dirt can jam up pretty easy.
  19. #59
    Mar 2005
    Foothills County
    is faster than yours
    My first guess would be wiring since one bank is working and the other isn’t. But some quick testing with the multimeter would confirm fairly quickly. I don’t think the Holley allows output testing the same way you can on a Megasquirt but if it does, that’s an even easier way to check.
  20. #60
    Feb 2020
    Edmonton
    Quote Originally Posted by never View Post
    The wiring hasn't been touched at all is the weird thing, its ran above the intake and really no work has been done that could damage it.
    I'm told a camshaft position sensor could cause these issues, the intake will have to come off. Normally not an issue, but on a 4th gen, its a pain.
    I'll be checking rhe 12v to all the injectors first thing along with the grounding through the ecu. Just super strange it stopped working at the same time I ran out of fuel.
    No output testing
  1. Pre build or build out a pc? Need to upgrade my home desktop
    By cycosis in forum Computer Help Desk
    Latest Threads: 02-28-2020, 01:16 PM
  2. Replies: 87
  3. FS:15" rims, from mid 80s pontiac firebird
    By fox in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 12-19-2004, 09:40 PM
  4. 17" rimsfor camaro/firebird/5-4.75 pattern
    By bol in forum Automotive Parts
    Latest Threads: 04-13-2003, 05:53 PM
  5. Me VS new Firebird. Got spanked BAD!
    By Daddymax in forum Street Encounters
    Latest Threads: 10-25-2002, 12:25 AM
