7 1 audio speaker setup - Page 2 - Beyond.ca - Car Forums
Page 2 of 4 FirstFirst 1 2 3 ... LastLast
Results 21 to 40 of 71
Thread: 7 1 audio speaker setup
    Aug 2006
    calgary/AB
    95B
    Quote Originally Posted by OU812 View Post
    So if I went the ceiling route those would replace the side speakers? Probably hard to fish that wire in now maybe I'll just leave it as side-mounted??
    Here is the Typical Dolby Recommended setup for 7.1. 2
    https://www.dolby.com/about/support/...up-guide/#gref
    If you don't want to do the ceiling you can go with Atmos speakers that sit on top of the front towers (If you are doing towers).
    There are bunch of speakers that offer that,
    https://www.visions.ca/product-detai...d=0&sku=Q50ABL
    https://www.monitoraudio.com/en/prod...abled-speaker/
    Or you can go with a front tower that has this inbuilt,
    https://www.focal.com/en/home-audio/...ra/chora-826-d
    Dewinton, AB
    Ok so I bought an AVR and its a 7.2. If I understand this right that basically means 7 speakers plus 2 subs.
    I was looking at the R-625FA Tower Speakers by Klipsh as they have built in ATMOS. On the back of the speaker they have two termination blocks. Does this get spliced together in the back and ran to the front inputs on AVR? Or do you wire the fronts to the one and the ATMOS becomes one of the surrounds??
    So confused hahaha
    Two of the terminals will be for the front R and L speakers. And 2 get wired as height channels.
    Do not splice. Run 2 audio cables or a cable with 4 conductors to them.
    Basically the Atmos heights on top are compeltlely different speakers as far as the amp is concerned.
    So confused hahaha
    Does your receiver have "Height" speaker output channels? If so that's that will connect to the upper terminals, while the Front output goes to the lower terminals.
    If your AVR is 7.2 rather than 7.1.2, you may need to run it as a 5.1 + the Height speakers if your AVR supports it.
    https://www.dolby.com/about/support/...r-setup-guide/
    Dewinton, AB
    Ok so how does that work though on the amp basically the back looks like this? so 4 wires come off 2 posts per side?
    I have no clue what I am doing. It decodes Atmos. Its a Denon AVR S750H
    The Surround Back outputs on that are assignable via the receiver setup menu and can be used as the Height outputs. You'll need to set up your other speakers as described in the link I posted above as this is not a 7.1.2 receiver.
    See the bottom picture here:
    https://manuals.denon.com/AVRS750H/N...SYpvilxnds.php
    Double check the manual for that amp before you buy atmos capable speakers.
    Just don’t want you buying speakers that aren’t compatible with outputting full atnos with height.
    You want to find very clear reference to height channels or Atmos capable speakers.
    Dewinton, AB
    Yes as Berserker pointed out I have assignable rears. I looked in the manual and it also states "This unit is equipped with a decoder that supports Dolby Atmos audio format. The placement or movement of sound is accurately reproduced by the addition of overhead speakers, enabling you to experience an incredibly natural and realistic surround sound field."
    So would you run it like he suggests or traditional 7.1?? Last time I dealt with this stuff 5.1 was cutting edge hahahaha
    Height channels are more important than 7 speaker surround. So do what he says.
    Dewinton, AB
    Thought on something like this??
    $800 USD was thinking of delivery to Sweetgrass and a quick road trip?
    I have that kit or a similar one to it. Make sure you pair with a good sub.
    Dewinton, AB
    You buy local? Where?
    I got it as a gift
    Maybe Costco?
    Dewinton, AB
    Yep .com not .ca
    Which part of the city do you live in?
    Dewinton, AB
    PMD you
    That receiver will only do 5.1.2 for Atmos.
    5 = LCR (left, Center, right) and 2 surround speakers.
    1 = Sub
    2 = 2 height (ceiling or upfiring) speakers
    The floor standing speakers with Atmos speakers on the top will work. you reassign 2 of the surround channels to height and plug them into the atmos upfiring speakers in the floor standing unit.
    Dewinton, AB
    1 = Sub
    Thanks that's definately the way im leaning. Figure it's better than a 7.1 layout
    I converted my 7.1 to atmos 5.1.2 and it’s a massive world of difference.
    Dewinton, AB
    Thats good to hear (no pun intended)
  1. WTB: 8" speaker adapter bracket for 6.5" speaker
    By Critical in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 08-24-2013, 05:30 PM
  2. FS: Rocketfish Wireless Speaker Rear Speaker Kit
    By im2fst4u in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-20-2010, 09:39 PM
  3. WTB: 4.1/5.1 speaker setup
    By Importworld in forum Computer Hardware & Peripherals
    Latest Threads: 08-26-2006, 02:24 AM
  4. WTB: 5.1 Speaker & Amp setup for TV
    By DowntownCowboy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-21-2005, 12:10 PM
  5. Nubbish question, speaker setup...
    By Mason in forum In Car Entertainment / Electronics
    Latest Threads: 05-31-2004, 08:06 PM
