why is my boiler system jizzing - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: why is my boiler system jizzing
    Oct 2003
    ute
    Default why is my boiler system jizzing
    Anyone have any idea why my boiler circuit for my in floor heating would be doing this? Looks like it's doing maybe 200-300ml an hour or so.
    I should know more about this, but at a glance, it looks like you're experiencing an over pressure and your pressure relief valve is lifting.
    Which isn't good.
    I mean... It's good in that the system is protecting itself... But it shouldn't be doing that.
    Oct 2003
    ute
    Which isn't good.
    Thanks. I turned the boiler off for now
    This is a closed circuit of fluid?
    Glycol in there?
    Valve stuck somewhere in the line?
    Almost looks like if you had low fluid and the pump is foaming it up.
    Admittedly, I don't know much about those systems.
    Aug 2003
    Medicine Hat, AB
    Which isn't good.
    Or the relief device is failing itself. This happens. I would depressurize the system and replace the valve before anything else. If it does it again, your pressure regulator/pump is failing (most likely) or the system is over heating (least likely).
    Oct 2003
    ute
    I don't really want to mess around with this stuff, so I think I'll call someone to risk their face instead of mine. I don't want to become Darkman.
    Any recommendations? Canyon?
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Mine was doing it too, replaced the valves no change. Is your system making any noise? My transformer for the valves is clicking super loud, but I feel like I let the air out and for a day or two it doesn’t.. I’ve been meaning to get it looked at but haven’t had time.
    Let me know what you find out if someone comes for a look.
    Oct 2003
    ute
    Quote Originally Posted by JfuckinC View Post
    @tirebob has a guy...i made a couple of adjustments to the valve and we'll see if that helps
    Aug 2004
    N/A V8, TTV6, DOHC N/A V6
    Good movie. Would you like to become Darkane?
    It’s only one letter off.
    -H.P. Lovecraft
    Sep 2012
    Your boiler system must have found your OF.
    Your boiler system must have found ES’s OF.
    ftfy
    Apr 2020
    W251 R550 4Matic
    That's an automatic air vent mounted to an air separator, without taking a look and seeing in person my guess is that the air vent despite looking new and shiny is faulty or more likely that the expansion tank directly beneath it had its bladder fail and the air is escaping into the system.
    Oct 2003
    ute
    Quote Originally Posted by MrFaust View Post
    thanks ya. it looks fine other than the jizz now all over it.
    That what she said...
    Sep 2008
    NE
    Shit, this sounds like what could have happened to mine!
    Apr 2020
    W251 R550 4Matic
    One of the things you can do to determine if the bladder in the tank has ruptured and whether or not the tank is water logged is to tap the bottom and top of the tank lightly with a screw driver, the part of the tank furthest from the piping connection should sound hollow when compared to the portion closest to the tank inlet, if it sounds like its full, or there is no discernable difference in sound between top and bottom of the tank it is likely water logged.
  1. Float Valve - Boiler Piping
    By JfuckinC in forum Home and Garden
    Latest Threads: 12-19-2021, 09:55 AM
  2. I want my boiler inspected
    By Buster in forum Home and Garden
    Latest Threads: 09-08-2016, 11:43 PM
  3. Bradford white - Electric Boiler parts?
    By Kobe in forum Home and Garden
    Latest Threads: 11-10-2014, 02:54 PM
  4. LF :: NEW Boiler Part - Honeywell Aquastat
    By syscal in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-28-2008, 07:55 AM
  5. Does anyone here have a boiler heating system?
    By Weapon_R in forum General
    Latest Threads: 11-12-2005, 02:58 PM
