Furnace inducer motor question. - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Furnace inducer motor question.
    Not Aspen
    Two from Freemont
    Default Furnace inducer motor question.
    Lennox 80UGH3/4-120A-3. 22ish years old. Furnace hasn't been firing.
    First time, I though it was flame sensor. I cleaned it. Ran for a while.
    Next time, I was checking to see if the inducer was seized and spun it manually. Fired up fine for a couple of days.
    This time, the only thing that would make it go was giggling the wires to the inducer. It goes into Watchguard mode otherwise. The furnace will start to spin up and I saw sparks in the red circle location. When there is a connection, the inducer spins fine. Seem like it is shorting out.
    Do I have to replace the whole thing, or can you service an inducer assembly?
    What's loose? The connector? Causing an arc or you think it's the wire connection in the clear plastic?
    You could try dialectric grease. Auto Value has small tubes
    Which ensures a better connection.
    If the arc is in the white plastic area and the connector is broken a bit in there, this won't fix that.
    Look for a parts diagram based on model # and see what parts they sell. That would indicate if you need to replace the whole part or not.
    Cochrane, AB
    Trucks
    Can you pull the connector off easily with just a tug on the wire? I’ve seen the electrical crimp connector misaligned a few times with ‘male-beside-female’ instead of ‘male-inside-female’, if that makes sense. (I’m sure Ask Leo can clarify.) Happens occasionally with insulated Sta-Kon crimp connections.
    If the broken wire is inside the motor coil I would just replace the inducer motor, not worth the headache dicking with it.
    Aug 2002
    992 T-hawk Golf R
    I’m just surprised you’re using the old furnace in your new build…. I guess you gotta save where you can with all of these cost escalations!
    I like neat cars.
    Can’t buy HVAC like old HVAC.
    Anyone and their dog can buy a new furnace. Buying a house just to get the old furnace that actually works at 80% efficiency is the true baller choice.
    Not Aspen
    Two from Freemont
    The arc is happening after the male who identifies as female connector. The black wire with the pink connector is working fine. The arc is revealing itself in the white plastic beyond the connector.
    I'll just find an assembly. Where's the cheapest place in town?
    Quote Originally Posted by 90_Shelby View Post
    This is at the MIL's place.
    Cochrane, AB
    Trucks
    I’d check with Soper’s Supply or Amre Supply for cash sales.
    Not Aspen
    Two from Freemont
    And we have ignition!
    Thanks Darell
  1. Replies: 25
    Latest Threads: 08-04-2020, 11:08 PM
  2. Replies: 13
    Latest Threads: 06-26-2018, 08:57 AM
  3. Capacitor For Furnace Motor
    By RickDaTuner in forum Home and Garden
    Latest Threads: 05-30-2010, 12:00 PM
  4. Furnace help!? Any Furnace techs on Beyond?
  5. Furnace motor
    By ramminghard in forum General
    Latest Threads: 01-30-2004, 08:28 PM
