Bike for the wife. What to look at - Beyond.ca - Car Forums
Results 1 to 20 of 29
Thread: Bike for the wife. What to look at
    Jan 2017
    Summer car or work truck
    Default Bike for the wife. What to look at
    Hey guys,
    I'm not too familiar with bikes and components. My wife is looking for something to replace her old sportchek modle. She is looking for a hard tail and will mostly be biking around with the kids on trails and pathways. Currently looking at the below based on similar prices. $800-$1000
    Norco storm 3/4
    Trek Marlin 5
    LIV tempt 2
    Any input? Thanks in advance.
    Coworker has trek marlin.
    Seems to like it. Basically used for bombing around with his kids on city pathways. Nothing too crazy.
    Hey guys,
    Norco storm 3/4
    Trek Marlin 5
    LIV tempt 2
    If thats all the riding she's going to do, then these kinda things don't really matter:
    Boost and Thru-axels
    Air shock fork, travel and stantion size
    1x Drivetrain
    To be honest, I'd say even a Diamondback or GT bike from Sportcheck (less than 1K) would be more than sufficient - both decent brands and quality. IF she wanted to step it up, yeah I'd say the LIV is a ladies designed Giant and probably will typically pack more value for dollar than even Trek or Norco.
    I would prefer Alivio as a minimal groupset, but I've heard Acera isn't too bad these days... anyways the money saved with a GT bike can be spent on things like Grips, Pedals and Saddle
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Out of that list I’d go storm 3, best package to be able to upgrade from if she starts to do a little more single track.
    The 9sp cassette means an HG hub that can easily be swapped to a 10-12sp 1x setup, which would probably go a long way to transform the bike for fairly “cheap” (for mtb parts that is haha) via kijiji take offs, clutched derailleur, more simplicity and probably better climbing abilities
    Jun 1987
    SK
    Fit Dugan Signature (2016)
    Just buy a stationary bike that she can move between the kitchen sink and laundry room.
    Originally posted by SJW
    Originally posted by snowcat
    ^^ Fact Checked
    Jan 2017
    Quote Originally Posted by ercchry View Post
    Why storm 3 over the 4? Worth saving the $100, same potential to upgrade later?
    - - - Updated - - -
    Quote Originally Posted by r3ccOs View Post
    1x Drivetrain
    I'd like to get out on some real trails with her when the kids get bigger, so want the best we can for the cost. I like the idea of being able to upgrade later. I'll get her to look at the GT, see what she says. Are they upgradeable?
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Storm 4 is a 7sp cassette, so you’d most likely need a new wheel set to “modernize” that one to a 1x drivetrain
    Obviously blowing the budget, but here’s an example of a fairly competent budget hard tail, the storm 3 would allow you to work towards a similar setup (sx and nx 12sp actually still uses the HG freehub vs the newer standards)
    https://www.commencalcanada.com/meta...21-c2x32930873
    Sep 2012
    I think there are a "few" options out there and I'll put it this way...
    for current riding - probably get away with a costco Northshore, or Sportchek GT or Diamondback.
    low range (I'd say up to $700)
    Most of these bikes will be based on "older" technology which means it will use a heavier 3x Drivetrain using a square taper bottom bracket, Quick relase front and rear axels (135/100 typically), a "non-taper" head tube with a small travel fork. Being that alot of the lower end bikes are being shipped with Microshift components, that's not a bad thing. Good value for dollar and everything hung off this bike is plenty durable. There will always be parts for these type of bikes, but upgradability for improved performance limited
    low-mid range ($700-1200)
    May not be stocked with great parts but has a good frame to hang better parts on.
    If you want to say upgrade to a 1x (single cog front) drivetrain ecchry said, you'll need something with more than 8 cogs on the rear (8 speed) so you can go up to 11 when you do that upgrade. This is not uncommon from what I can see BUT, alot of the "Better" 1x upgrade sets are made for "Boost" which is for bigger "thru" axles (which are 15-20mm thick and 110/148 wide) that thread into the frame or the fork unlike the old 9mm quick release.
    Fork... this is another thing. If you want to put a burlier fork on there, which makes all the difference on a hard tail, you need to look for a frame with a "tapered" head tube as bascially any half decent "new" fork uses a tapered head tube. I think the GT avalanche (1K) comes with one, so that's a good thing... but unfortunately it isn't using boost thru axels.
    mid-highish rnage ($1000-$1500)
    This is where I see frames that are boost thru-axel, tapered headsets, more modern geometry and usually with threaded BBs, which means you can basically go sky the limits with anythign. However at this price point, even though the frame is capable, the parts are mid-range. SOMETIMES and you have to be careful, you may find what looks like a good bike but has an older or odd spec Thru-axel (Marin/Sombrio) that may impact upgradeabilty or parts availablity in the future (i.e. buying a replacement hub)
    I think that something like a GT avalanche which has resonably progressive geometry, and though quick release is probably more than plenty out the door...
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Re: 1x and boost… boost specific kits are going to have a 3mm offset on the chainring so chainline is straight on the wider boost hubs, if you 1x a non-boost, hg freehub bike you can purchase shifter/derailleur in your favourite model that hopefully also has the right range for the cassette size) then you will need the sram sx/nx cassette if you go 12sp, or if 10 or 11, whatever cassette you want (can also get “off brand” 12sp hg cassettes), then chain ring is as simple as finding a narrow wide that has the tooth count you want and correct BCD pattern and width for your crank arms without a boost offset(since these bikes are probably not coming with direct mount rings)
    Oct 2003
    ute
    need pics of wife.
    need pics of wife.
    Just inseam to judge frame size?
    didn't think you could go 12x with HG, but I guess if someone makes a compatible cassette that's cool as its a PITA to have to go from HG to microspline or SRAM XD.
    I think if its anything for non-boost its the crank... I'd say with SRAM/Truvative its true that you can just buy any crank (SX/NX/GX/X01) and that its just about getting the right narrow wide tooth CR (i.e. 3mm for Boost), but I can't recall if its the same with a cinch style newer RF crank and not 100% sure about availabilty for non-boost 1x shimano cranks (i.e. deore+)
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Yeah, like mentioned in here already, these bikes use older standards, so lots of options from wolf tooth/absolute black/etc. for replacement rings
    Subaru Outback
    My wife bought a Kona Dew last year and loves it for riding on bike paths with the kids.
    not going to lie, this looks like a good deal
    https://www.decathlon.ca/en/mountain...jectID=4230776
    Not terrible fork from a reputable company with a Tapered head tube
    Deore 1x 11 Drivetrain with huge range 11-51
    Boost Wheels/Frame
    Hydraulic brakes (they're "ok") and at least has a 180 front Rotor
    this is an XC claimed style bike and I don't see a Geo, so I'd imagine its very traditional 69 deg head tube, 73 seat tube and moderate reach
    The only things I'd be weary about vs. a Trek, Specialized, Giant is whether the wheel set is any good and maybe the cockpit (bars/saddle etc..)
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    ^^last pic has specs, but you were pretty close haha, 69.5 degrees and seat is 71-73 depending on size
    It for sure ticks a lot of boxes, plus cockpit tweaks are way cheaper and easier than drivetrain. Shorter stem and different rise bar would transform its trail manners for sure
    not going to lie... the spec's are very decent especially for racing. If the wheels are tough enough, and you had the motor... you could walk into decathlon and be all in for $1400 bucks on kit and shoes and be racing same day.
    Jan 2017
    Too bad there are no small frames available. ^^
    is she small small? My wife who's 5'9 who should be sized med, prefs large
  1. EK2.0, do you like your wife's new look?
    By max_boost in forum Entertainment
    Latest Threads: 01-09-2010, 12:54 AM
  2. Taking a look at an 87 Supra Turbo, What to look for?
    By TEAMFaint in forum General Car/Bike Talk
    Latest Threads: 02-24-2007, 01:02 AM
  3. Audi/BMW/VW lovers don't look (MB guys look lol)
    By /////AMG in forum Cars, Bikes, Machines
    Latest Threads: 01-13-2005, 09:17 AM
  4. look...again....(this one doesnt suck so look...)
    By toxic_slick in forum Photoshop Gallery
    Latest Threads: 11-04-2004, 10:51 AM
  5. look look look
    By stradplaya454 in forum Photoshop Gallery
    Latest Threads: 10-09-2004, 12:13 AM
