When you bleed the system, what did the fluid look like?
Did it come out clean or like a black slurry? When the seals in the master/slave start to break down it creates a black mess in the fluid.
Clean.
Do you have a high frequency vibration or odd feeling in the clutch pedal when you press it? I think the clutch pressure plate spring is broken, or the engine crankshaft is loosing its thrust bearings.[/QUOTE]
No vibration or frequency noises.
