My Acreage Project - Let the fun begin - Page 4 - Beyond.ca - Car Forums
Page 4 of 23 FirstFirst ... 3 4 5 14 ... LastLast
Results 61 to 80 of 455
Thread: My Acreage Project - Let the fun begin
  1. #61
    Oh, that's not what I was imagining, at all. I thought the modularized walls were finished with windows, siding and possibly even drywall. I think that company called Landmark does this, somehow.
    Still awesome, just that something from earlier made me think it was different.
  2. #62
    Nov 2005
    Great thread so far, what a fantastic project to share with Beyonders.
  3. #63
    Apr 2004
    LX 5.0
    What goes in between the floors, and the earth beneath? Is this area insulated or just sealed off somehow?
    Neat project.
  4. #64
    2020 Subaru Forester Sport
    Quote Originally Posted by s dime View Post
    Neat project.
    There goes an L shaped frost shield insulation, and then treated plywood to cover up the gap. Think some BlueSkin goes around that after the fact...but not too sure. They delivered BlueSkin stuff, so I am pretty sure it's going to go around the foundation insulation to seal the gap.
  5. #65
    Apr 2004
    LX 5.0
    Thanks, I see it now, the whole place has a concrete floor. Ill follow this thread closely, would love to do something like this in the future.
  6. #66
    Went out there early this morning to take a look at what was done yesterday, and looks like they are installing 3X LVL beams sandwiched together, plus a few pieces of insulation, to make up the 8" wall thickness. These go around the entire perimeter and support the whole roof structure above, and transfer the load to the screw piles. Kind of neat, didn't know about this detail of the build.
    They also reframed the two small vertical windows to their proper height. Someone at the factory screwed up.
    LVL all around:
    Reframed windows:
  7. #67
    Daaayum! Them walls be thic!
  8. #68
    May 2004
    Ford, Acura
    Are you going to spray foam insulate or fiberglass batten?
    I'm generally cute.
  9. #69
    2002civic's Avatar
    2002civic is offline Held my GTI hostage and got unbanned
    May 2003
    19 SQ5/22 Pilot BE/18 RS3
    following, awesome project!
  10. #70
    What kind of attachments are here and here?
    That header will be under a lot of stress and it looks like it's only resting on that one (assumed 2x8).
    *Not Structural advise
  11. #71
    Quote Originally Posted by schurchill39 View Post
    Spray foam the whole ma-faka, this is conditioned attic, cost of sprayfoam > $100k!! Whole place will be a spray cave, even under concrete.
    Good question. I noticed this as well when I was out there a few days ago. I will take a look again tomorrow when I head out. I know they haven't fully finished framing that area out, as right now it's just an LVL on the double door, but the single door is framed out fully. I will check to see. You are right about lots of weight, the whole loft + roof will be sitting on that 16' span. I just just notice that there is 2" of plywood sticking out, leads me to believe that a 2x8 is going into that area still on each side.
  12. #72
    So was out there today just to clean up around the site a little bit, and took some more pictures. They have braced the whole building to square it out, and started putting up the roof and loft. The roof will be pointy, there is a triangle that still goes on top, I think they build it this way for easier transport.
  13. #73
    Went out today to do some cleanup and took some pictures to further clarify this:
    As you can see, the framing around this isn't finished as both doors will be same height:
    This is the detail on the back of the small door. I suspect it will be exactly same on the big door. Why it's not framed in yet I am not sure, perhaps has something to do with the stairs they still need to bring in for the loft, perhaps they need the clearance.
    Also got around to fly the drone again just for fun. Some random shots.
  14. #74
    Jun 2007
    ATS, XC90
    Drone shots are cool shots.
  15. #75
    No major updates. Have been out of town for a few days and checked today and the roof is nearly completed.
    The stairs for the loft are in the open area, so there is more complex framing involved
  16. #76
    Well things are moving along. They are sheathing the roof right now, but overall looks pretty much the same, so I didn't bother with any pictures. Yesterday I started and today finished up my little generator shed. The bitch is heavy to move, so I didn't want to move it anymore and just build a little house around it. I need it to run the well pump for the time being so I can get water to seed/water the grass on the septic field....unfortunately, it appears that the pump is a dud. Called the septic guy and he was sure it wasn't the pump and some generator problem, but luckily there is another construction not too far away and I drove buy and was able to have them quickly drop by with their generator to test, and same thing, no water. The generator changes tone like there is a load, but no water ever comes out. With two generators not able to get the pump moving, I think something is wrong with the pump. The guy who installed the pump will come out sometime and have a look. I know it's a brand new $1500 pump in there as I was there when it was installed, but it was never tested at that time, so could have been dead from the start, which is very unfortunate.
    Anyways, here is my little shed for the pump. Used all refuse material they had on site, cost me absolutely nothing. Had a pack of shingles laying around so decided to shingle the top as well.
    I originally made a platform to move it around easily with a tractor, so I just build around this platform so I can still move it to a new place later on.
  17. #77
    2008 Z06
    I def thought that was a dog house at first glance.
  18. #78
    Well my well guy has gone MIA....after agreeing to meet me Tuesday and being responsive over the weekend, I haven't been able to reach him for all of this week...fml
    Anyways, progress is going, mostly just sheathing at the moment. Some updated pics:
    Loft (8' ceilings, hard to get idea of the space from the picture. Stairs will be around where the ladder is sticking out.)
    Few angles of the house. The two large roof section will join at the peak, they haven't built that part out yet
    Hopefully some more exciting updates soon.
  19. #79
    Like the place. Hope your guy shows up.
  20. #80
    2008 Z06
    Loft looks good, nice and deep. 70ft?
    Current Cars:
    2004 GMC 2500HD 8.1L
    Past Cars:
    1970 Chevy Blazer, 2wd
    2005 Jeep Wrangler LJ
    1989 5L Mustang
    1990 Jeep Cherokee
  1. FS: 2006 RCM 125SX Mini Dirtbike FUN FUN FUN!!!
    By wahsabi in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 06-15-2007, 04:14 PM
  2. Let the modding begin!!
    By Gondi Stylez in forum General Car/Bike Talk
    Latest Threads: 03-20-2007, 04:21 PM
  3. Let the finals begin......
    By nismodrifter in forum Campus Chat
    Latest Threads: 12-26-2004, 02:08 PM
  4. Pics of my GT - Let the flaming begin
    By Kronyk in forum Cars, Bikes, Machines
    Latest Threads: 07-31-2002, 09:12 PM
