no 5 and 6 gears after clutch install - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: no 5 and 6 gears after clutch install
    Apr 2010
    Default no 5 and 6 gears after clutch install
    hey all,
    2012 civic si, after installing the new clutch, i cannot get to 5 and 6 gears
    1 2 3 4 R all working fine./
    probably will bring back to the mechanic, but thought any of you guys might know why.
    im thinking its the shifter cables
    Probably a shift cable doesn't have the anchoring C clips on so cable is lose in the bracket.
    Apr 2010
    dont they have to line up with something?
    Apr 2003
    F10M/F87/NA2/W220/V90/E46ZHP/SE3P/DC2
    Bring back to whoever did it. Dont fuck with it. Otherwise he can blame it on you.
    Apr 2010
    yea thanks, will bring it back today
    Quote Originally Posted by rach View Post
    Just if those clips aren't in, the whole cable moves and actually doesn't move as far in one direction. The inner part of the cable is what should move.
    For whatever reason (tough in text to explain but similar to a bike cable adjustment barrel). If the whole cable moves, it explains why you can get into gears that pull the cable (1&2) as it is in place and outer cable doesn't move; can get into gears where cable is slack or not moving (3&4) and can't get into gears that push the cable (5&6) as the clip is missing.
    I believe this is a simple fix. Not to worry that your transmission is broken or clutch installed wrong.
    You might say....
    Getting clipped is important?
    You might say....
    That + Vtec = 9.0s car.
    Post the name of the shop so we know who to avoid.
    Mechanics who are too lazy to go on a 10 min test drive and end up missing something like this, then cost me half a day to bring my car back to fix their problem is a major trigger for me.
  1. Looking for someone to install gears for a '95 mustang
    By Klobi-1-Kinobi in forum Mechanical
    Latest Threads: 07-03-2014, 08:16 PM
  2. s13 has no clutch pressure / wont shift into gears... pls help!!
    By ken.bryle21 in forum Nissan 240sx / Silvia Owners
    Latest Threads: 09-04-2011, 10:59 AM
  3. FS: Auburn pro diff, 3.73 gears, install kit
    By skylinegtr20 in forum Automotive Parts
    Latest Threads: 08-15-2009, 03:19 AM
  4. Integra Close Ratio Gears Install
    By jdm_teg_gs in forum Performance Modifications
    Latest Threads: 01-14-2008, 01:09 AM
  5. FS: 3.42 gears for GM 10 bolt with install parts
    By sasukekun in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 06-26-2004, 03:51 AM
