Nissan brake pads and rotors - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: Nissan brake pads and rotors
    Aug 2003
    Cochrane
    Default Nissan brake pads and rotors
    I'm looking to replace pads and rotors on our 2016 Rogue. Parts are expensive now!!
    OEM Nissan $921
    Nissan value brand $661
    I've previously used Brembo and Powerstop and they're had issues are 2 years. Anyone recommend any other brands for someone doing their own brakes? Is Nissan OEM worth it over the Nissan Value brand?
    Cheers.
    Feb 2018
    2013 328i, 2020 BMW F900 XR
    I would go to Napa or another parts store to check with them. My guess is they'll be much cheaper. Or even RockAuto.com.
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    I'm ordering from Rockauto soon. I have some semi-coated Centric rotors and pads in the cart, but willing to hear others recommendations for brands.
    $452 for my Infiniti incl shipping
    Aug 2003
    Cochrane
    Quote Originally Posted by gmc72 View Post
    Thanks I just called them as well. $600 for their bottom tier. Not sure if they're good or not.
    Rock Auto is my next option - I've never heard of any of their brands before!
    Aug 2002
    992 T-hawk Golf R
    Have you measured the rotor thickness to confirm that they're out of spec and need to be replaced? Or are they warped? (Pulsing brake pedal when stopping)
    I like neat cars.
    Canadian Tire just had a sale on their mid/upper tier brand that they call OE+. Might be worth pricing those out.
    These prices sounds crazy for a Murano!
    Aug 2003
    Cochrane
    Quote Originally Posted by 90_Shelby View Post
    I have. All the rotors are warped! Only 50k of mostly highway too.
    - - - Updated - - -
    The prices are a bit cheaper but that's what we have now on the Rogue. The quality just wasn't there with the Canadian tire ones.
    I would say Canadian tire "house brand" stuff is on par with the cheapest stuff from RockAuto in terms of quality. which isn't a ringing endorsement. The better quality brand name stuff from RockAuto or a "real" parts store like NAPA would be my strong preference.
    Aug 2003
    Cochrane
    Thanks, this is really helpful! It leads me back to the Nissan "value" line at the moment.
    Have used Centric that had the hubs coated. No complaints on rotor warpage yet.
    I know more than a few that don't brake hard enough and glaze the rotor and end up with constant squealing on light braking.
    Aug 2002
    992 T-hawk Golf R
    Quote Originally Posted by B69 View Post
    - - - Updated - - -
    If you're looking to save cost, I would have them machined and continue running them. The shop that resurfaces them will tell you if they're within spec or not as well.
    I like neat cars.
    Lot of shops won't machine rotors anymore at all, and if they will, sometimes costs more than new. Worth checking this before you commit to one course or the other.
    If I was buying from RockAuto, I'd go with the Raybestos "fully Coated" line for corrosion resistance, just because I am like that. https://www.rockauto.com/en/catalog/...+pad+kit,13824
    I just bought OE+ pads and rotors and they cost more than the Brembo that Cdn Tire had, so I'm certainly hoping for more than that.
    I might return them due to a convoluted, lame story though.
    C-Spot
    I feel attacked.
    Where's my post about doing panic stops in the odyssey? Ah here it is: https://forums.beyond.ca/threads/404...66#post4680866
    Nov 2021
    E46
    - - - Updated - - -
    When you install the rotors, make sure the hub surfaces are clean. Just down to bare metal, including around the wheel studs. Roloc disks and wire wheels work well for this. Install the rotor on the hub, hand tighten three lug nuts down to hold the rotor on the hub. Using a dial indicator (a cheap one from princess auto will work) measure the rotor run-out. The max spec for this is 0.035mm. If it is out of spec, take the rotor off and turn it 180 re-install, then measure run-out again. If it is still out of spec, you need to buy better rotors.
    If the rotors have too much run-out. The brake pads will hit the high spot and deposit pad material onto the rotor causing a brake pulsation. Highway driving will make this worse. If you are having repeated pulsation problems, the hubs have too much corrosion on them or you are buying too cheap of parts.
    X5D, Fiesta ST
    I usually just buy the cheapest rotors because they crack before they warp, but that’s a me problem.
    I feel attacked.
    Brake harder.
    Quote Originally Posted by Twin_Cam_Turbo View Post
    Post in humble brag thread please. Not here. Haha.
    C-Spot
    ^ My brakes squeal but only because its been like 4 years since last set.
    I make sure and bed them in nicely when new.
  1. LF: someone to install new back brake rotors and brake pads
    By mard in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 06-12-2009, 07:12 PM
  2. New brake pads and rotors for 7th accord from Honda for free?
    By go77306 in forum General Car/Bike Talk
    Latest Threads: 01-06-2005, 11:04 AM
  3. Brake Upgrade: Pads and Rotors
    By Weapon_R in forum Mechanical
    Latest Threads: 06-08-2004, 08:21 AM
  4. BMW Rotors and Brake Pads!
    By Zephyr in forum Mechanical
    Latest Threads: 06-27-2003, 05:44 PM
