Ziplines? - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: Ziplines?
    Nov 2003
    Calgary / AB
    '13 MazdaSpeed 3, Zoom Zoom!
    Default Ziplines?
    For most topics out there beyond has an opinion....
    Looking to put up a zipline for the kids, but there is a dizzying amount of choices available.
    Anyone have experience with any brands or vendors they'd recommend? Or ones to avoid?
    My Karma ran over your Dogma
    I have been involved in buying and putting up two of the slackers ziplines. They work. Shop around, the same kits are sold multiple places.
    The longer ones are a little harder to put up, because you need to keep some tension on it or you'll run out of room to tighten with the turnbuckle. Helps to have 2-3 people, but it's not complicated.
    I put up this 90 foot one earlier this year.
    I assume this would help tension it.
    https://www.amazon.ca/Dutton-Lainson...88970816&psc=1
    Or use a pulley and winch system to tension it up.
    Most people I know diy it and just buy the bearing runner part from a decent source. Key is keep the bearings out of the weather if you can.
    Thaco's Avatar
    Oct 2004
    Rage2
    just use a ratchet strap to pre-tension it, 6 ft should be enough, but you can get like 20fters
    User title molested by Rage2.
    ^^ Fact Checked
    Just to be clear to any who have not set one of these up before, the lots do include a turnbuckle to set the final tension. However, it has a limited range of movement, so it's helpful if the cable is sorta tight to start with. Lots of ways to accomplish that.
