DIY Outdoor Trimlights - Beyond.ca - Car Forums
Results 1 to 20 of 37
Thread: DIY Outdoor Trimlights
    Default DIY Outdoor Trimlights
    Lot of people have been asking how I did the DIY version of the trimlights and costs, etc.
    Here is the how-to below with sources for materials and the total cost after I returned excess wire spools, etc.
    $664 including shipping.
    A number of hurdles to get over but overall I am happy with how it all looks. I will add pics to this original thread as I find them.
    I originally wanted to do channel like the picture here but realized after closer inspection the existing fascia was not square at all leaving a ton of obvious workmanship issues that I couldn't control.
    Thanks to @gretz for offering his sources to bend the J-Channel for me if I went this route.
    My old fascia with the new channel below it. Much better plan on the anchoring, less bends and labor and chance of cracking the already painted J channel.
    Another pic of backside showing how tight it is to majority of the existing fascia board.
    DECIDE WHAT LED SPACING YOU LIKE
    https://www.trimlight.com/spacing-options
    Extensive reading led me to use 8” spacing. Gemstone uses approx. this spacing. But you can order in various spacings from the LED suppliers.
    TOOLS NEEDED
    Stepper drill bit for drilling holes in channel
    Measuring tape
    Drill press.
    Hole Jig made from 1x4 and 2x4 base, 12mm dowling, 2 screws to attach wood together, quick grips to hold correct spacing on drill press.
    Drill
    Tiny drillbit for pilot holes when mounting channel
    Drill with Robertson bit for mounting channel
    Bungee cords to help hold channel while mounting
    Extension Ladder or two with safety arms for stability
    PROCESS
    Test fit the J channel, decide on anchor point and placement to hide wires, direction of LEDs, etc. with existing fascia setup.
    Build a jig for the hole placement and start drilling.
    My starting hole on each channel is 4” from the edge so that when the next channel is butt up to it, it will equal 8”.
    Drilled all the starting holes at 4” first
    Reset the job to 8” centers off that first hole and drilled the rest of each channel.
    Name:  Hole Sizing.jpg
    Jig setup for hole drilling
    https://www.youtube.com/watch?v=3CA6AC5xiRk
    Setting up for install
    Plan out your starting point. Actually plan out the whole route and segments.
    I started at the furthest corner from my power and data cable source to start mounting.
    Worked from corner to the end of led string which was along the side of the house.
    Counted out the LED’s for the channels moving towards the end along the side of the house and kept cuts to the far end at the back out of sight.
    Then started on the other side of the corner piece working along the front of house towards the power source and Data signal source.
    - Note, power can be brought in at any point on the string. Data signal has to be from beginning of the led segment.
    Built corner piece. Using these instructional videos on bends, etc.
    https://www.trimlight.com/installvideos
    I soldered in power injection to last 100 pixels which was the very end of the line of LEDs.
    Power injection was also placed in the middle of the string too (Led 100) as per my Power Injection calculations. See below for Calcs and information.
    LED PIXEL LIGHTS
    Ray Wu Store
    https://he.aliexpress.com/store/7017...ad_203195030.0
    8” Spacing is what I ordered/used.
    8in(20cm) spacing 100pcs/set square regulated type DC12V
    https://www.aliexpress.com/item/1005...668927707%21sh
    4” Spacing if you like that look
    4 inches(10cm)100pcs/set DC12V square 12mm WS2811 RGB led pixel node
    https://www.aliexpress.com/item/4000...799834134%21sh
    IF YOU WANT EXACTLY GEMSTONE STYLE LEDs USE THESE
    Paul Zhang’ Store AliExpress.
    [email protected]
    12V 30mm RGBW 50 Pixel Outdoor LED Permanent Track 20 cm spacing (8”).
    https://www.aliexpress.com/item/1005...28906424%21rec
    12V 30mm RGBW 50 Pixel Outdoor LED Permanent Track 10 cm spacing (4”).
    https://www.aliexpress.com/item/1005...14455727%21rec
    POWER INJECTION
    Power Injection Explained
    http://spikerlights.com/pwrinjection.aspx
    Power Injection Calc
    http://spikerlights.com/calcpower.aspx
    Wire Rolls to purchase
    https://www.princessauto.com/en/prim...10-045-025-005
    Additional information
    https://electricfiredesign.com/2022/...le-led-strips/
    https://www.cerrowire.com/products/r...pacity-charts/
    J CHANNEL
    Purchased locally – best price I found.
    https://www.metalworkscanada.com/
    Catalog of sizing
    https://www.metalworkscanada.com/wp-...-catalogue.pdf
    X = 1.00” worked best for me.
    Jig setup for hole drilling – reposted link
    Drill bit for sheet metal holes
    https://www.princessauto.com/en/13-s...t/PA0008256430
    Install Videos / Corner shaping
    LED CONTROL & POWER SUPPLY
    Dig-Uno Wifi LED Controller – uses WLED.app on Google Play or Apple App Store.
    https://quinled.info/pre-assembled-quinled-dig-uno/
    MEAN WELL LRS-150-12 150W 12V 12.5 Amp Enclosed Switchable Power Supply (Might be undersized on Amps for me)
    https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
    Junction Box ABS Plastic Dustproof 8x8x3 size
    https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
    VARIOUS ADDITIONAL PARTS
    Various Conduit pieces from Home Depot
    Shrink sleeves
    Solder
    Flux
    Electrical tape
    Lumex
    Wire clamp anchors
    ATTACHED PHOTOS
    Progress:
    Corner piece on:
    Side of house on and tested:
    End of the LEDs still hanging as I needed to solder the power injection point in there.
    Wifi Controller and power supply testing:
    Next part was the step down. Had to cut the LED line and solder wires to achieve this.
    Close up and am going back to anchor the lumex covered wires for a cleaner look:
    Reserved for more photos
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    I'm gonna rep you so hard
    She wishes it was deep.
    So deep put her ass to sleep.
    Thaco's Avatar
    Oct 2004
    Rage2
    Cool build, i'll have to look in to that place for the J trim for my 2nd floor, i just used off the shelf J trim from Home depot, and it was just barely wide enough for the pixels
    just a note to save costs a bit, a computer PSU works great, very easy to modify for use as a bench supply for projects like this, and they get constantly thrown away. Also i put the whole thing on a smart plug so i can power cycle it if needed, occasionally this is needed if wierd stuff happens and it makes it a whole lot easier depending on where you mount the PSU/Controller
    And a note for anybody that wants white, find an RGBW (cool or warm) or RGBWW (cool and warm which can be mixed) strip, the RGB cant really simulate whites very well
    User title molested by Rage2.
    ^^ Fact Checked
    missy
    Holy Jeeze…. Makes my whole flood light in the front yard look mildly less impressive
    Nice work man
    CNC Guru*
    Instagram: goreski_rdd
    Thanks guys!
    Yeah Thaco makes some good points above. I'm willing to offer advice or clarify any questions.
    Definitely look into the wider J channel, helped a lot and not that much more costly than HD.
    At first, a place that does custom bends had me quoted for $500+.
    Pushing in those leds on the ground would be preferred and find a way to get them all hanging at once. Had a few different new ideas for getting it all in place.
    Boom lift would help a ton.
    @gretz When this is 100% done I'll probably get bored and start dialing in the efoil build and parts list.
    Thaco's Avatar
    Oct 2004
    Rage2
    Thanks guys!
    When i did my lower section, i just cut the strings off wherever the trim piece ended and added connectors on, that way i can easily drop one whole section if needed.
    ^^ Fact Checked
    I'm getting hard about the reps I'm gun give...
    hey mike, any thoughts, reviews or guidance on the software? Pretty easy with WLED, or how did you find it?
    WLED falls between, idiot proof: Trimlight or Gemstone app and having to program it all yourself.
    It's not that well documented but I've been able to get what I want out of it so far.
    I have it programmed to turn off and on at certain times.
    Presets created for different effects I want. Setup my default pattern.
    Can definitely tell you how to get solid colors or do the patters.
    Future: Figure out how to control single led by single led but that appears to be needing programming.
    Figure. Out a random light show at specific times over Xmas. Say a new pattern every hour or something.
    Next question, how much for MR2MIKECO to install this system on my 2-story house?
    Sep 2006
    Secret City, Alberta
    2018 Civic Si coupe
    More than you can afford pal.
    Probably $23/foot.
    Stampede Central
    is pretty sharp lookin'
    Quote Originally Posted by Swank View Post
    Art room entry included?
    C-Spot
    This is also my question, as I don't like ladders or heights.
    Sep 2006
    2018 Civic Si coupe
    Unaffordable.
    QUOTE would be with Boom lift. No way I'd do a second floor without it. Unfortunately, Energy companies are swamped so my day job is pretty busy. Ask again at break up.
    This guy art rooms.
    https://youtube.com/shorts/9jbFXjlCrG0?feature=share
  1. Outdoor Carwashing
    By Davide in forum Society / Law / Current Events / Politics
    Latest Threads: 03-08-2005, 01:00 PM
  2. Outdoor Soccer 2005
    By Shaolin in forum Sports, Health & Fitness
    Latest Threads: 02-16-2005, 02:12 PM
  3. WTB: UofC parking pass (outdoor).
    By Skyline_Addict in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-25-2004, 11:42 PM
  4. NEEDED: girl to play soccer for our outdoor soccer league
    By gkAeris in forum Sports, Health & Fitness
    Latest Threads: 06-03-2004, 06:31 PM
  5. outdoor paved rinks
    By LUDELVR in forum Events and Meets
    Latest Threads: 05-13-2004, 08:37 PM
