Looking for a plug in timer that does seconds. - Beyond.ca - Car Forums
Results 1 to 20 of 25
Thread: Looking for a plug in timer that does seconds.
    Oct 2007
    YEG
    Lotus and a Honda.
    Default Looking for a plug in timer that does seconds.
    Did not think I would have this hard of a time finding soemthing to accomplish this. Cheaply anyways.
    Smart plug or timer doesn't matter. Just needs to do this.
    Example
    At 4pm timer on. Timer off after 15 seconds.
    At 530pm timer on. Timer off after 15 seconds.
    Any suggestions?
    Cereal Killer.
    @iambrianspilner
    V8s
    No suggestions, but I'm interested in the use case.
    Aug 2002
    992 T-hawk Golf R
    DIY gemstone lights
    I like neat cars.
    Oct 2007
    YEG
    Lotus and a Honda.
    Misting system for plants and reptiles. 1 min is too much, need less.
    Cereal Killer.
    @iambrianspilner
    Cochrane, AB
    Trucks
    An air compressor drain valve timer will do up to a 10-12 second burst. Just power it off a regular 24hr time as the drain timer are usually only good for up to a 1 hr delay. (and these valves are made for water/air mix)
    https://www.amazon.ca/s?k=compressor...f=nb_sb_noss_2
    Jul 2011
    Ford F150
    I've seen Raspberry Pi setups for similar things. Handy if you know Python?
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    If you already have a smart device, see if IFTTT has a solution? Taking a look through none of my devices seem to do less than 1min increments though
    Edit: actually you can use an Alexa/google/whatever assistant timer to trigger an on/off for a smart plug, that could probably work
    Quote Originally Posted by 90_shelby View Post
    diy gemstone lights
    lol.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Okay, solved…
    Have a smart power bar, brand is globe suite… bought it at CT for cheap, it talks to google assistant, within assistant you can set routines, and can add a time delay in seconds between actions. So can set a time to start the power, time delay, then turn off:
    Would assume many brands would work the same way as the programming is via assistant, not the device (which does not do seconds in its own native app btw)
    Oct 2007
    YEG
    Lotus and a Honda.
    Oh shit that's perfect! ^^^ I'll def look into that.
    After digging into every Amazon timer I found this one. Looks like it doesn't have a clock so it's just a reputation timer.
    BN-LINK Timer Outlet Short Period Repeat Cycle Intermittent Digital Timer, Interval Timer - Day, Night, or 24 Hour Operation, Programmable Plug-in Timer for Appliances Electrical Outlets 15A/1875W https://a.co/d/fzlASVX
    Cereal Killer.
    @iambrianspilner
    Sep 2003
    Defender, Allroad
    I bought this from HD for Halloween. You on the app you can create On or Off events by each plug individually. The app isn't great but it can do what you wanted.
    https://www.homedepot.ca/product/gee...lug/1001343653
    Quote Originally Posted by npham View Post
    Won't meet his 15s spritz timing.
    Oct 2007
    YEG
    Lotus and a Honda.
    Cancelled the timer, @ercchry nailed it. Downloaded assistant that was already paired with my Google home network. And then that gave me the option to delay seconds.
    Cereal Killer.
    @iambrianspilner
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Nice, love when tech works!
    Oct 2007
    YEG
    Lotus and a Honda.
    Quote Originally Posted by ercchry View Post
    Funny how the Google home app has the same routine page but without the seconds delay option. Was just an app away!
    Cereal Killer.
    @iambrianspilner
    Hybrid
    This is definitely not a use case that I'd trust something that needs internet connectivity to handle. My blinds run on Google assistant routines and there have been a few instances that it has missed the trigger. Obviously not critical if my blinds didn't open once or twice in the morning, but it might be if your trigger to turn the mister on works but the trigger to turn it off doesn't.
    The many amazon reptile mister timers aren't suitable? Those look better than the google routine to me. I use google. Home routines for basic reminders around the house and they aren't reliable.
    Oct 2007
    YEG
    Lotus and a Honda.
    Yea I was thinking about it missing a beat and unloading 2 gallons of waters in the tanks. That would suck.
    And extraslow, I have the one you posted plus the other Amazon mister system. Both are pump and controller In one and the pressure sucks. I've upgraded to an actual misting pump and it's only ran by power. So now I need to get this sorted.
    There is an actual seconds timer from a company called mistking, but they've made it so you can only use their pump with the controller.
    Hmmmmm. Gonna play around with the Google today and see how it goes.
    Always open to more suggestions or timers!
    Cereal Killer.
    @iambrianspilner
    Only 15min from Aspen!
    Nothing interesting anymore
  1. FS- Kensington travel plug adaptor, Apple keyboard/mouse, Apple Powerbook plug
    By RawB8figure in forum Computer Hardware & Peripherals
    Latest Threads: 12-12-2007, 10:58 PM
  2. fs: apexi turbo timer, greddy turbo timer
    By spoolint78 in forum Automotive Parts [Engine Electronics]
    Latest Threads: 01-24-2007, 02:01 AM
  3. fs: greddy turbo timer, hks turbo timer
    Latest Threads: 11-09-2006, 03:45 PM
  4. FS- GReddy e-Manage, turbo timer and Apexi V-AFC and turbo timer
    By Bigchuckers in forum Automotive Parts [Engine Electronics]
    Latest Threads: 09-15-2005, 11:57 PM
  5. WTB: ecu plug ins for a 1989-91 civic just the plug i need some pins for my swap
    By eeseen racing in forum Automotive Parts [Engine Electronics]
    Latest Threads: 09-21-2004, 08:32 PM
