Battery Tender recommendations - Page 3 - Beyond.ca - Car Forums
Results 41 to 60 of 72
Thread: Battery Tender recommendations
    '18 Murano
    Quote Originally Posted by bjstare View Post
    You have to change your brake fluid when too much moisture builds up in it, not based on a certain timeline. It's really easy to test it to figure out how much moisture is there, but most techs/service advisors just recommend you change it every two years because it's easy money for them, an easy sale, and 99% of people don't know/care enough to debate it.
    I don't recall it ever being an issue on older cars. Is ABS a factor in this?
    Nov 2021
    E46
    Brakes on old cars are terrible, everything leaked from poor seal technology.
    It's not just ABS, it's also ADAS systems. The brake fluid goes through a hydraulic module with computer-controlled valves and pressure sensors that direct the fluid to where it needs to be. These valves are very close tolerance and will score and stick if debris goes through them.
    Advanced driver assistance systems use the brakes for lane keep assist, adaptive cruise control, and emergency stop. The brake fluid viscosity affects how long it takes for the wheels to start decelerating once brake pressure is applied. This amount of time is factored into stop-distance calculations that ADAS modules do. Having old/incorrect fluid can change how long it takes to stop the vehicle. Apparently, a bunch of new low-viscosity brake fluids are coming out to help speed up brake functions. There is very little easy money left in vehicle maintenance.
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    Adding brake fluid change to list for spring... First time for everything.
    She wishes it was deep.
    So deep put her ass to sleep.
    Elboya
    I squeeze it all out every time I change pads. (Which is still nowhere near often enough, likely).
    Racing or AutoX would certainly get more frequent
    Echo RS
    Depending on the vehicle every track day to every year for track use I find.
    Nov 2017
    4Runner TRD Pro
    I have noco Genius 5's one each for my supra and type r. the supra runs 24/7 no issues what so ever
    N/A V8, TTV6, DOHC N/A V6
    Brakes break?
    -H.P. Lovecraft
    Dewinton, AB
    I ended up getting the Noco Genius 2. We will see how it goes.
    around
    Quote Originally Posted by OU812 View Post
    Iíve worked on some European equipment that was meant to sit outside in freezing temps plugged in and they used battery tenders, mostly c-tek brand. I think that if the battery will be subjected to freezing temps itís important that the tender/maintainer is sized appropriately. If itís going to live inside a small one is fine.
    Originally posted by InRich
    I think it should be a MINIMUM payment of 20% across the board for any kinda house. Who can't save 20% nowadays, just stop eating out, drive a japanese shit box, and save, its not hard.. have some fucking discipline. Half you niggers shouldn't even be in the houses you live in now.
    we can't all drive X5Ms
    This exists. Not sure how to order one.
    Elboya
    ^Sweet, get one. 240V at 50Hz shouldn't be no thang.
    Nothingburger Hill
    Garbanzo Bean
    I like that it's a thing.
    Nothing a transformer can't handle.
    Elboya
    Calgary, Canada
    958.2 Cayenne Diesel
    Porsche has been recommending every two years on the Cayenne, which seems like overkill, but I essentially bend over to keep warranty intact.
    Originally posted by arian_ma
    your stomach is full of sulfuric acid
    '18 Murano
    Quote Originally Posted by Neil4Speed View Post
    Thanks, all. Guess I'll pay closer attention to it.
    Anyone know of any Noco Boost type products that work on 6V batteries?
    Not a tender, those are easy enough to find. But a booster.
  18. #58
    Nothingburger Hill
    Garbanzo Bean
    I'd want to look closely at this to make sure it's "really" 6V, but, napa website shows one. https://www.napacanada.com/en/p/MBC85924
    At least it doesn't look like a Liberty Walk fucked a Subaru Outback.
  19. #59
    Thx
  20. #60
    Sep 2007
    A vehicle or two
    The Noco is ok. I have a CTEK that does the job well.
    General comments:
    1. Under no circumstance should you start the car and run it for a few mins. Or even 30 mins. Don't start the car unless you intend to take it for a drive. Starting, idling, then shutting it off is bad and doesn't help in any way.
    2. Plug it in and leave it all winter if you want. That's the whole point of getting a tender/smart charger. Wiring up some connectors with a plug on the end is a great idea.
    I have a CTEK as well, and it's been fantastic. As for your comments, I'm glad you made comment #1 especially. The biggest draw on your battery is during start, so by starting it, you actually immediately drain it. I do think running it for a while DOES help, but Bjstate is right in that only by driving it and getting the RPMs up there does it do a good job of charging.
    I also agree with his second comment, whereby the purpose of a "smart" tender is that it will shut off and only activate when required. I leave my CTEK hooked up to my Jag all winter without issue.
  1. New car battery, brand or vendor recommendations?
    By cidley69 in forum General Car/Bike Talk
    Latest Threads: 09-08-2021, 08:22 PM
  2. I need Battery recommendations.
    By Graham_A_M in forum Bike Talk
    Latest Threads: 04-01-2014, 12:58 PM
  3. Where to buy "Battery Tender" locally?
    By BMDUBS in forum General Car/Bike Talk
    Latest Threads: 11-30-2011, 03:20 PM
  4. Battery Tender
    By Euro_Trash in forum Home and Garden
    Latest Threads: 09-14-2011, 09:23 AM
  5. Battery Tender vs Battery Charger
    By ruggedboy in forum Bike Talk
    Latest Threads: 03-05-2009, 08:58 AM
