fuel pressur spec - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: fuel pressur spec
    Apr 2004
    Ellensburg / Wa.
    1988 Isuzu Trooper
    Default fuel pressur spec
    need fuel pressure spec on 1988 Isuzu Trooper II with 2.6L 4 cylinder engine. Runs poorly, and has 15-16 PSI.
    Feb 2004
    Medicine Hat AB
    It is a little bit of a procedure.
    1. Install the gauge between pressure regulator and distributor pipe. Unplug the VSV (Vacuum Switching Valve) Start engine and measure pressure under all of the following conditions.
    Disconnect pressure regulator vacuum hose. Plug intake side of the hose. Pressure shoulg be 42.6 (3.0 kg/cm2.
    Reconnect pressure regulator vacuum hose and allow to idle. Pressure should be about 35.6 (2.5 kg/cm2)
    Shut off engine. Disconnect vacuum hose from pressure regulator. Pressure should be 35.6 (2.5 kg/cm2)
    Apply batter voltage to the VSV, reconnect vacuum hose, and allow engine to idle at 900 rpm. Fuel pump pressure should be 42.6 (3.0 kg/cm2). If the pressure remains unchanged, replace the VSV.
    Hope this helps!
    Apr 2004
    Ellensburg / Wa.
    1988 Isuzu Trooper
    Hey, thanx for the info. Yep it was a worn out pump. New pump installed "pegged" my 35 lb gauge, and now the old Troop runs like new again! Thanx again for the specs.
    Feb 2004
    Medicine Hat AB
    No Problem,
    Glad to help where I can
  1. Replies: 6
    Latest Threads: 12-22-2003, 01:56 AM
  2. FS: Buddy Club Racing spec fuel managment
    By shadowz in forum Automotive Parts
    Latest Threads: 07-14-2003, 05:37 PM
  3. SE-R or Spec-V?
    By szw in forum General Car/Bike Talk
    Latest Threads: 08-07-2002, 02:01 AM
  4. My Silver Spec V pics
    By GingeRRRBeef in forum Cars, Bikes, Machines
    Latest Threads: 07-31-2002, 04:22 AM
