Sealing Vinyl Stairs Edges? - Beyond.ca - Car Forums
Results 1 to 20 of 25
Thread: Sealing Vinyl Stairs Edges?
    Feb 2009
    Family Hauler
    Default Sealing Vinyl Stairs Edges?
    Hello handymen of beyond, what would you do to seal these bad boys?
    I don't have the luxury of a baesboard to cover up my 1/16 of an inch gap, I haven't really tried any translucent DAP or anything but don't think that would look good...
    Is the answer to cut slivers or board and seal over top of that once installed?
    (Yes, the white painted part is not finished either I know it looks like shit)
    Let me know your thoughts!
    #buildergrade
    Quarter-round?
    Feb 2009
    Family Hauler
    Quarter-round?
    I did consider that, and it would cover things up perfectly, but I honestly haven't done this before so don't know - Maybe that is the best solution
    Or a bead of caulk, which is faster but might look shitty. Not sure.
    Would a bead of ordinary paintable caulk be so bad?
    Thaco's Avatar
    Oct 2004
    Rage2
    dap is crap, it shrinks and cracks, get proper caulk
    User title molested by Rage2.
    ^^ Fact Checked
    Feb 2009
    Family Hauler
    Im unsure of whether painted caulk would look silly next to the wood texture / design of the stair.
    Oh shit I forgot I have another picture for context
    Edit: I guess I don't... I bought a tube of 'color match' seal from a flooring store, tested three out to find closest color and tried one. It looks like shit and Ill need to finish it again
    Only 15min from Aspen!
    Nothing interesting anymore
    Personally I would caulk it, but I love throwing my caulk around. Quarter round won't go around the stair nosing, so would look weird to me.
    After a month you won't notice either of them anyways.
    Feb 2009
    Family Hauler
    Go on....
    - - - Updated - - -
    Maybe you're right. I did all this myself so I notice all these little gaps and they drive me nuts.
    I mean it’s going to be wood pattern against painted surface no matter what way you slice it.
    May 2004
    Ford, Acura
    Tape off the edge of the stair to ensure you get a nice crisp edge then run a paintable caulk. When you smooth it out really push on it and get in in there tight with a small radius. Pull line and repaint everything white.
    I'm generally cute.
    V8s
    Don't do quarter round, there's no way to finish it nicely there. If it's truly 1/16 gap, not 1/4 or 3/8, white caulk/dap is what you want.
    If you use dap, lay a bead, wipe excess with your finger, then do a light final pass with a slightly damp rag (doing this last step saves you the trouble of taping the stair surface).
    Thaco's Avatar
    Oct 2004
    Rage2
    agreed, a white caulk with a nice taped off finish on the stair side would be the cleanest, and fade in to the white of the wall.
    ^^ Fact Checked
    Feb 2009
    Family Hauler
    Quote Originally Posted by bjstare View Post
    Most of them are truly 1/16... I may have one or two that are a bit bigger......
    Would you use something other than DAP? And yes appreciate the notes on how to apply, thats what I've done for my baseboards across the entire house
    DAP -> Finger -> Wet Cloth -> Redo any step if I f'd up
    Sep 2012
    Carpet.
    Feb 2009
    Family Hauler
    Carpet.
    This would have made my life easier there is no doubt
    Less is more. But that's obvious with white caulk.
    Lesser is more if you find yellow caulk.
    Not Aspen
    Two from Freemont
    what about brown caulk or black caulk?
    I would just leave it. should have cut it to tighter tolerance to begin with as vinyl shouldn't need room to breath for expansion and contraction. then no caulk required.
    I think the truth is the 45° finishing trim piece should barely touch the edge of the stairs, then you can run the bullnose finishing piece someone else mentioned.
    Or else leave it.
    Impossible to cut perfect against warped walls in old houses.
    Sep 2012
    Quote Originally Posted by riander5 View Post
    Just carpet the sides. Easy to do yourself and you just need to staple it in.
  1. Installing vinyl runner over undeveloped basement stairs
    By EG STyLeZ in forum Home and Garden
    Latest Threads: 06-13-2014, 03:32 PM
  2. LF: Place to "hem" scrape carpet edges
    By TomcoPDR in forum Home and Garden
    Latest Threads: 07-06-2011, 11:15 PM
  3. frosted clear vinyl/vinyl tape
    By lastprodigy in forum Cosmetic and Styling Modifications
    Latest Threads: 08-08-2005, 06:04 PM
  4. Fuzzy Edges
    By Melinda in forum Photoshop Gallery
    Latest Threads: 10-24-2003, 02:02 PM
  5. Rolled Edges on my Body Kit. Can I do this myself?
    By scooby_dooby in forum Performance Modifications
    Latest Threads: 04-15-2003, 03:26 AM
