Mounting Privacy screen on raised concrete deck - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: Mounting Privacy screen on raised concrete deck
    Not Aspen
    Two from Freemont
    Default Mounting Privacy screen on raised concrete deck
    So I have this dilemma.
    Want to add a screen and need to mount 2 posts like attached photo. Posts would be 6ft high above the deck surface. Deck is 2' off the ground so I would use an 8' post.
    The thought I had was to use concrete anchors and bolt it to the side so that it has some lever strength for chinook type winds. But I can only find anchors that leave maybe 1/2" - 1" of thread which is not enough to bolt a 4X4 post. Or is it?
    Do I just ignore the instructions and mount the anchor less deep to give me more slack? Seems suspect.
    The other though is I could mount it on the deck surface with and adjustable post base:
    Another idea would be to mount the post base horizontal and then attach the post in to the post base that way on the side of the deck.
    thoughts?
    The SHBARUS
    or get some galv. steel angles?
    Stampede Central
    is pretty sharp lookin'
    Why not go into the ground?
    And then do the tie-in into the concrete horizontally for extra stability.
    https://www.homedepot.ca/product/sim...4x4/1001400316
    Only 15min from Aspen!
    Nothing interesting anymore
    Dig down. Use 12' posts. Concrete them in like fence posts. Strap them to the concrete for extra strength.
    V8s
    This
    Oct 2004
    Rage2
    expansion wedge anchorsName:  71+UbqoCvWL._SL1500_.jpg
    User title molested by Rage2.
    ^^ Fact Checked
    Countersink hilti-bolts by about 1.5" into the 4x4 posts to let them bite into the concrete more.
    Digging them (the posts) in and tying into the structure is getting into the "put them on screw piles and footings" territory.
    Jun 2003
    Canada
    GMC Sierra
    Do you know the thickness of the concrete wall? Most wedge anchors will not be long enough for this application. You can use redi rod/washer/nut for this application and anchor them in using two part epoxy anchoring adhesive (ie. hilti hit, Simpson makes a good epoxy). Follow the epoxy manufacturers directions for hole size and cleaning method. I have used this for installing engineered glass railings on concrete decks.
    Figure 4" for concrete embedment, 4" post thickness, 1" for washer/nut. So 9" redi rod, or make them longer and cut the excess off after. 2 bolts, top and bottom for each post. Top hole should be at least 3" below top of concrete so you don't blow the top out when drilling.
    Edit: the countersink suggestion is a good idea too
    Jan 2017
    Summer car or work truck
    Quote Originally Posted by sxtasy View Post
    This
    Not Aspen
    Two from Freemont
    Perfect, this is what I was looking for.
    Am I the only person who thinks it's far simpler to have them sitting in anchors on the TOP of the patio?
    Simpler for sure, but won't last as long, especially if he's in a windy area. I tend to overbuild things though. Most times it's paid out to do so.
    Not Aspen
    Two from Freemont
    yeah, that's my worry. If it was a 3ft railing, I would be less worried. But since it is 6' high and basically a sail, the torque on the mount is even greater. I am sure some engineer could do the math.
    Sep 2012
    Since when do 'geers do math.
    Jun 2003
    Canada
    GMC Sierra
    Don't overtighten the nuts when installing, you could break the bond on the epoxy if you are really cranking it down. Just snug it up, you could use a locking washer. Countersinking it slightly in the wood does look better, just use a spade bit same diameter as the washer.
    May 2004
    Ford, Acura
    We don't, we only send emails. The most math we do is the =sum() function on excel
    I'm generally cute.
    Another reason is you'll probably get gross staining on the concrete surface over time from the metals. On the side, the water hopefully drains and dries.
    But also with the leverage, the wind will loosen off and probably shear the bolts going in perpendicularly to the wind forces.
    Consider something like this which allows adjustments.
    Super windy, it could be opened to allow flow.
    https://www.amazon.ca/Flex-Fence-Dec...68885926&psc=1
    I've got the same along my entire west fence, and it's awesome. They get loose over a summer, so I put in a wooden dowel system to set them where I want them. The wind pushes them closed, so if you want to alleviate the wind pressure, you have to do something like I did to hold it open.
  1. Deck Privacy Ideas
    By Asian_defender in forum Home and Garden
    Latest Threads: 07-15-2015, 08:07 PM
  2. Replies: 4
    Latest Threads: 08-04-2009, 06:37 PM
  3. F.S. Mounting bracket for flat screen T.V
    By itsnotaDUB in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-01-2007, 03:53 PM
  4. Raised aero bed..anyone try one of these??
    By Redlyne_mr2 in forum General
    Latest Threads: 10-28-2002, 11:20 PM
