Wanting to add a filtered water tap.. - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Wanting to add a filtered water tap..
    Feb 2005
    Cummins F10
    Default Wanting to add a filtered water tap..
    I'm looking at adding a tankless RO system.
    Any personal experiences? Any plumbers on here?
    I'm interested in the one below:
    https://www.amazon.ca/dp/B08PYHJ8CJ?...WFFA87A05SW07C
    Originally posted by Mibz
    The criteria for being a Beyond Baller is simply knowing you are one.
    Deleted F10 535d
    My hybrid burns Diesel & Oil
    Does that go under your sink or in the utility room? If under the sink, you can likely DIY without too much trouble.
    Cochrane, AB
    Trucks
    I had something similar, was slow to fill a container. Added an expansion tank and the faucet now comes out full blast for 1 gallon. I’ve since switched to a large commercial filter bank in the basement after adding a refrigerator with water and ice. No need for filters all over the house. Make note that RO systems have a waste volume of like 80%, if that matter to you. (needs a drain line connection)
    '14 Taco
    Had a under-sink RO unit explode overnight in our first house and came out that morning to 2" of water on our main floor. Insurance ended up replacing pretty much entire kitchen area and our developed basement... be forewarned!
    Feb 2005
    Cummins F10
    the one in the link above goes under your sink.
    Deleted F10 535d
    Sep 2012
    If you have pex it's very easy. Put one in years ago at the old house.
    Jul 2007
    VAG products
    Had an RO system put in to our utility room and ran up to a separate tap in our kitchen. Worked pretty well, and I was less worried if it leaked since it was in the basement.
    I can pass along the info if you are interested
    May 2015
    B16 Spec V, 97 SC400, 15 Caravan
    You just need to think about the why behind this. RO is quite a wasteful treatment process with little gained. At most I would put a particulate filter at the line coming into your house. This is less about your health but protecting your appliances, this goes along with a water softener. If you are on City water, I question anything more than a softener.
    When we had a well, we had a full treatment train, along with UV disinfection, but we were only paying for the pumping of that water.
    Hardest part is drilling through your better than builder grade granite counter.
    Feb 2005
    Cummins F10
    Quote Originally Posted by Cagare View Post
    If you like the taste of tap water, then have at it!
    I personally cant stand it
    I've grown tired of filling up our Brita multiple times a day, and wanted an easier and more permanent solution.
    the bits aren't very expensive... just the mistakes are!
    Deleted F10 535d
  1. Filtered Earplugs (for concerts, gigs, etc)
    By magicalpoop in forum Entertainment
    Latest Threads: 06-20-2012, 10:28 PM
  2. why does my tap water smell/taste funny
    By Afrodeziak in forum General
    Latest Threads: 05-27-2008, 06:31 PM
  3. tap Tap Tap - Poor old audi
    By Outie4000S in forum Mechanical
    Latest Threads: 02-22-2006, 10:52 AM
  4. Tap Water Vs. Bottled
    By Mo Squared in forum General
    Latest Threads: 12-30-2005, 03:32 PM
  5. Wanting to add...
    By JokerFMJ in forum Performance Modifications
    Latest Threads: 07-28-2004, 09:08 PM
