Duplex sound dampening party wall - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Duplex sound dampening party wall
    Mar 2014
    Default Duplex sound dampening party wall
    I'm gettingName:  20230929_121549.jpg
Size:  305.7 KB various drywall companies suggesting different things so I'm getting in a rabbit hole about how to do this right.
    One person suggested roxal insulation with soundbar and 5/8 drywall and another person said roxal doesn't provide any more sound resistance than owens quiet zone insulation.
    Another company said to see 2 5/8s with "green glue" on each side of the wall (essentially 4 layers between me and the other side.
    Anyone have known proven ideas? Also looking for ideas for the ceiling cause it has a legal basement suite.
    Mar 2006
    I briefly lived in a side by side home, new build. And the builder used 2x6 walls on either side of 2" air gap, 2 - 5/8 boards on either side as well. No fancy insulation or sound board built into the wall.
    It did not 100% stop the noise transmission through the wall. I see you are using 2x4 so i don't think you will see any real benefit from over thinking this.
    Only 15min from Aspen!
    Nothing interesting anymore
    Poured cement.
    Sep 2012
    Poured cement.
    Concrete.
    Jun 2005
    51N, 114W
    has 3rd party insurance
    the typical setup is:
    5/8" gypsum boards (type x)
    2x4” wood studs spaced 16” OC
    1 layer of 3” Safe’n’Sound® Wood Stud
    Resilient Channels spaced 16” OC
    this gives you a STC of 45 which i think for legal suites is 42?
    Aug 2011
    Strathmore
    2005 Dirtymax
    A lot of people are recommending this stuff https://www.homedepot.ca/product/son...ick/1000441119 over top of drywall.
    Mar 2008
    Didsbury
    GTIR->SE-R->RDX->SLT->S60->LS460
    Another consideration (sorry to add to the rabbit hole) is HVAC ducts and vents.
    Sound is like water, if there's a hole somewhere, it'll find it.
    That being said, each cumulative layer of sound diffusion, mass and air gaps all work together to mitigate sound propagation. You want the highest cumulative STC (Sound Transmission Control) rating. So for your example, ideally you'd want and STC rating of 50 and higher.
    https://en.wikipedia.org/wiki/Sound_transmission_class
    Stupidity is a disease we all have, it's like a form of brain herpes. Outbreaks will occasionally occur.
    May 2004
    I built a home theatre with a friend last year. After a ton of research we went with safe n sound in the walls, then a layer of green sonopan, then resilient channel, then 2 layers of 5/8 drywall with that acoustic seal green glue stuff in between. The reduction in sound is massive. It wasn't cheap though and it was a ton of work.Name:  PXL_20220317_034257121.jpg
    Sep 2012
    That's an impressive 7 inches.
    Mar 2014
    Quote Originally Posted by Ca_Silvia13 View Post
    I realize it's impossible to stop all noise, even with a concrete party wall. What kind of nosies did you notice come through?
    Mar 2014
    Quote Originally Posted by lamp_shade_2000 View Post
    I really like this. I think using one layer sonopan pan and then one 5/8 will be enough since my set up is off center studs and the drywall won't be attached to their unit
    Mar 2006
    Quote Originally Posted by jabjab View Post
    Raised voices/yelling and you could hear when the neighbour walked up and down the stairs.
    Jul 2007
    VAG products
    Concrete.
    Our party wall is ICF and we hear nothing
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Lived in a concrete party wall duplex once… could always hear their phone ring… concrete condo, always hear a yappy pocket dog a floor up. Seems to be the high frequency crap that cuts through
    Mar 2014
    Luckly our stairs are on the opposite sides. I'm ok with hearing low frequency sounds but don't want the higher frequency stuff like yelling and sex sounds.
    I think sound insulation may have helped it a bit in your set up.
    2020 Subaru Forester Sport
    I heard that open cell spray foam is also very good for sound deadening. Do your research, but perhaps you can drywall the one side, and then spray foam the entire cavity and drywall the other, and be good. I don't know the cost, but the fact that it will get into every nook is pretty appealing. Sorry I'm a big spray foam guy, love that stuff. When I did my basement long time ago as a theater, I researched the hell out of this as well and realized it can get very expensive very quick, so in my case all I did was resilient channel, but in ideal world it would have been that + two drywalls with that green glue, and some batts in the cavity.
    Mar 2014
    What we decided to do is double 5/8 drywall with green glue in between with Owens corner quiet zone batt insulation for the party wall.
    Basement will be resilant channel with the quiet zone batt and 5/8 drywall. Hoping for best.
    Bunch of Honda's
    What does your realtor suggest?
    Also all this shit is set by the Building Code... so your builder/architect/realtor should be telling you what to do, not the other way around.
    Jan 2005
    Who's building this?
    Mar 2014
    Quote Originally Posted by RawB8figure View Post
    This is a JV with a friend who is taking the other side. He is a smaller builder in Calgary but doesn't do too many attached homes. He says code is fine in the units he has done but I want a little extra.
  1. Wtb: dynamat or any sound dampening film
    By cidley69 in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 12-19-2016, 12:28 PM
  2. Sound dampening
    By black_2.5RS in forum General
    Latest Threads: 12-03-2008, 12:46 AM
  3. Replies: 2
    Latest Threads: 08-06-2007, 10:37 AM
  4. dampening the exhaust...
    By eur0 in forum Performance Modifications
    Latest Threads: 11-20-2002, 02:57 AM
