1961 land yacht… Beyond needs more builds build. - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 33 of 33
Thread: 1961 land yacht… Beyond needs more builds build.
  1. #21
    Dec 2005
    not calgary
    changes every year
    Quote Originally Posted by gretz View Post
    Been a bit, time for an update… trans is built, upgraded clutches and all. Went with a new hughes converter and a burst shifter to do the dirty work. Hooker Blackheart hemi swap headers were needed and landed the outlets perfectly, new intake mani gaskets, machined some egr gasketed block offs, intake made, rad in and plumbed with upper/lower hose sensors, one for each electric fan, batterybox in, all wiring done and tucked with an obd port in the ashtray, new fuse box in the glove box, and all factory gauges work, even the speedo will work as the cable is identical to the factory. Finished the headliner and rear deck / made a bow where the front and rear seams as well… What’s left?
    Bolt the trans
    Hookup the shifter
    Tranny mount
    Driveshaft
    Retrofit headlights
    Attachment 116755Attachment 116756
    Hp tuners tune to get rolling
    And exhaust built. Should be kicking before Christmas if all stays on track
    Fuck. Yes.
  2. #22
    missy
    Another slow update, transmount is done, new tank is in, car fires up… then shuts off. Used hp tuners to try and bypass security, wired the factory ignition and everything, no dice. So, buying more credits and unlocking another ecu is the next step cause who doesn’t want to throw money in the garbage. Headlight retrofit is done and new front buckets are in, mounts and console to come. I went with rx8 seats with the red inlay, match the rear seats and brushed trim throughout and I can essentially host a casting couch episode in the backseat with the amount of space after removing the front couch. Hoping for more exciting updates to come
    CNC Guru*
    Instagram: goreski_rdd
  3. #23
    Aug 2011
    Strathmore
    2005 Dirtymax
    What ECU are you using? P01 or P59?
  4. #24
    missy
    Couldn’t tell ya off the top of my head, it’s from an 06 charger RT, I’ll have to take a look next time I’m around it
    CNC Guru*
  5. #25
    Aug 2011
    Strathmore
    2005 Dirtymax
    Oh for some reason I read vats in there. You could talk to Sentry from here and they might be able to help solve stuff.
  6. #26
    missy
    He came down and played over a few beers, kinda confirming a few things / it’s definitely security related… maybe the ecu is garbage / was in the fritz and won’t accept the tune, so I’ll try one more before dumping my sons college money on a standalone
    CNC Guru*
  7. #27
    Sep 2008
    Turbo stuff
    Did you end up trying an un-cut harness on it?
  8. #28
    missy
    We built another harness with just the needed to run wires, ecu pretty much right on top of the motor, same result. I may have to bite the bullet and just go stand-alone with a swap harness, but want to rule out the ecu as a dud first. The previous hemi owner said it would shut off randomly on him which is why it was parked, so my fingers are crossed for this being the potato… or it’s just us lol
    CNC Guru*
  9. #29
    missy
    Well, it’s been a summer. It’s alive and kicking. Did a disc conversion with off the shelf parts and a dual res brake master cylinder from a 96 fuso 3 ton to keep the factory booster. Also, so I don’t die with the single pot and good luck everybody to the left or right drums. Turns out the hemi ecus are known to be shit, so I’m on the hunt for another. And compatibility between years is also a mystery I guess as there’s zero people that know anything, so the research begins. Still a laundry list of little button ups to keep me busy before I hit it with the paint roller when the snow comes Name:  IMG_6625.jpg
Size:  155.0 KBName:  IMG_6639.jpg
    CNC Guru*
  10. #30
    missy
    Also, for the ricer in me, had to do the rx8 seats that match the factory rears. The front bench was punched to shit, I’m guessing the previous owner was a farm animal of sorts, so I went the bucket route. Made a lot of gummers in the forward look group cry with my abomination. Made custom side panels for the trunk, por the hell out of it and sound deadened everything, spent wayyyy too long sitting in the trunk cutting the carpet… good thing I’m only 2 feet taller than m.alex. Stereo is all Bluetooth to my phone, no head unit, kinda zippy
Size:  142.2 KBName:  IMG_6299.jpg
    CNC Guru*
  11. #31
    Dec 2005
    not calgary
    changes every year
    Sweet. Agree with the gummers on the seats though, that's....different lol
  12. #32
    Elbonia
    Jeep of Theseus
    Dig the dual master with remote res, clean solution.
  13. #33
    missy
    Thanks man, made the res because screw buying shot when I can design and machine it over the course of 1000hours lol
    CNC Guru*
  1. Condo: value of old builds vs new builds
    By ee2k in forum Real Estate / Finance
    Latest Threads: 08-22-2015, 11:21 PM
  2. land yacht by my house? lots of them.
    By Fly Fishin' in forum General Car/Bike Talk
    Latest Threads: 02-27-2015, 10:15 AM
  3. FS: 1961 Land Rover S2 *SOLD*
    By DeathBy240 in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 03-27-2012, 04:29 PM
  4. 1961 pontiac catalina 8 door limo
    By big A in forum General Car/Bike Talk
    Latest Threads: 07-24-2007, 09:22 PM
