Who in Calgary or close can do this? Ive got some wheels that are correct bolt pattern, but require the center bore to be milled to a certain diameter to fit over hub.
@gretz used to, not sure if he still does.
I appreciate the shoutout but currently not taking on more work. Too swampered
CNC Guru*
Instagram: goreski_rdd
see if blackbird will do it. They did it on my BBS LM a while back.
Calgary Rim Repair at Flint Road might be able to do it
- - - Updated - - -
ETA: it's more turning than milling, turn out the hub diameter
They might use a vertical lathe though, which kinda looks like a mill
Cam or Matt might take it on.This quote is hidden because you are ignoring this member. Show Quote
+1 to ask blackbird.
