Originally Posted by
haggis88
First noticed a small shake around 90-100km/h, assumed tire balance
Had tires changed to winter at the same time I had the van in for the timing belt change, shake still there but mechanic noticed the engine mounts were worn out.
Drove it with the minor but constant shake at all speeds, worsening when VCM was active at highway speeds, whilst waiting on parts shipping and me not being away at work
Replaced all engine mounts, including active mounts (for the VCM system i assume)
Constant shake gone at low speed but now a worse shake has appeared between 90-120km/h, mostly on acceleration but is definitely more noticeable when the car is warm as opposed to when first driven. No CEL present.
Had a look at the visible drivetrain components, nothing seems to be hanging off (CV axles/boots intact) or loose. Brake rotors were new in the spring, tires are defo balanced
What would be next in ones process of elimination?
