Ford Duratec 30 Fuel Leak - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Ford Duratec 30 Fuel Leak
    Default Ford Duratec 30 Fuel Leak
    Raw gasoline smell in cabin that only smells if the car isn't moving and the heater fan is on. So, it's under the hood and extremely minor. Fuel economy unaffected. No visible drips, puddles or stains based on very preliminary inspection.
    This is the Ford 3.0L V6 from the early 2000's that was in piles of Fords and Mazdas.
    If you know of any typical issues associated with this, please let me know.
    Someone is using the back seat of your truck to cook meth
    I'm not overly familiar with those engines, but I had a similar issue on my Audi 2.7tt, and it was the fuel rail o-rings. Since you aren't seeing any puddles, it might be from an injector, and dripping down the side, burning off immediately on the exhaust.
    Yes I'd look in the engine bay for sure.
    Different motor but I had a similar issue with the MIL's Grand Cherokee V6. Fuel rail was leaking under the engine cover so you couldn't visibly see anything, no puddles on the ground but the smell of fuel, especially when in the garage.
    Mar 2006
    Check the EVAP cannister. There is a line that vents the gas tank. Look for wetness/dried fuel marks on the hoses.
    I can smell it in the engine compartment. Stronger smell towards the rear bank but it's a crowded slut on that back side. You can't see much of fuck all without removing the plenum.
    Dislike.
    Someone told me "loose spark plugs"... That sounds hysterically wrong, to me. Had anyone else ever heard of that as an option?
    If a spark plug is loose enough that it's blowing raw gas back out the threads, it won't be a problem for long.
    Did you check the turboencabulator?
    YouTube has a good video explaining the operation of that vital part. It's a but technical, but nothing an eit can't handle.
    Feb 2003
    DT 780
    LEXUS LX470
    its probably pretty dark back there to see the leak. I would run the engine and then use a lighter or propane torch to illuminate the leak. Make sure you park outside and wear safety glasses and have active insurance.
    Tap, Rack, BANG!
    Jan 2017
    Summer car or work truck
    And a camera rolling....
  1. 98 Pathfinder fuel leak?
    By Hage69 in forum Mechanical
    Latest Threads: 10-02-2012, 08:15 PM
  2. 92 Stanza fuel leak - help!
    By cccostanza in forum Mechanical
    Latest Threads: 11-01-2009, 10:38 PM
  3. Whats The Best Leak brand to stop powersteering leak
    By 88CRXGUY in forum General Car/Bike Talk
    Latest Threads: 07-05-2006, 08:36 PM
  4. only gettin 4 psi??? boost leak? vac leak?
    By |SpEncaA| in forum Forced Induction Talk
    Latest Threads: 04-03-2006, 01:45 PM
  5. Vacuum leak / Boost leak
    By Zenshi in forum Calgary MR2 Owners Club
    Latest Threads: 09-25-2005, 10:03 PM
