what the cuck?This quote is hidden because you are ignoring this member. Show Quote
It's nice out. First campfire, gotta enjoy them before it's banned.
Side note: Delhi hit 52.3 Celsius, and summer hasn't even really started yet.
DXY 100
I'm no expert, but that seems pretty hot for a Deli.
Wouldn't all of the meat spoil?
If you're used to eating street meat in Delhi then you're fine.This quote is hidden because you are ignoring this member. Show Quote
I’ve heard it’s called “experiencing culture”This quote is hidden because you are ignoring this member. Show Quote
It'll certainly be an experience to remember.This quote is hidden because you are ignoring this member. Show Quote
Would you describe it as, explosive?
I thought Pemmican kept pretty well forever? Fuck I have a lot to learn about Indian culture.
It does if you're strong enough.This quote is hidden because you are ignoring this member. Show Quote
Where do i buy this firepit?This quote is hidden because you are ignoring this member. Show Quote
Burnco (or whatever they are now) used to sell it, not sure if they carry them anymore. This is the manufacturer though, so look around for it.This quote is hidden because you are ignoring this member. Show Quote
https://www.barkmanconcrete.com/prod...wood-fire-pit/
Do you actually like your beer that warm?
He's being artistic. I assume he picked that up immediately after the photo was taken, drained the glass and refilled it before any substantial heating could occur.
Direct Landscape in Caresland appears to sell that firepit. If you like concrete/brick fireplaces, that seems like a good one. Could probably work out some air intake ports below the bottom course of bricks too if you were crafty.
Those bricks stay stone cold even with a much larger fire than I had that night. Also fireside beers don't last long enough to get warm.This quote is hidden because you are ignoring this member. Show Quote
I actually did something like that. I didn't buy the entire kit with the liner, but sourced two slightly smaller liners, turned one upside down, and bolted them together with spacers. If you notice the one in the photo is floating above the bricks, because that's the air intake with about 1/2" of space between the top, and 1" in between the liners the entire way around the pit, and the entire side of the bricks is still protected from direct fire.This quote is hidden because you are ignoring this member. Show Quote
Edit: like this
Now you got me thinking about this. Maybe DIY something for the inlaws cabin. an air intake would reduce smoke quite a bit.
just get a solo stove. they're dope. Plus their super burn mode is fun to stare at
Divine retribution for the call centersThis quote is hidden because you are ignoring this member. Show Quote
