So what are you guys carrying in your truck when you go wheeling? I've got the following:
- Tree strap
- Snatch block
- 3/4" shackles
Anyone out there using kinetic ropes?
- Tree strap
- Snatch block
- 3/4" shackles
never forget the shovel.... never..
Originally posted by rage2
Just because you're older... doesn't mean you need older women. Nothing wrong with an 18 year old here and there!
A girl who doesn't mind playing in mud.
thats better then the shovelOriginally posted by Phuqu
Jack-All (hi lift)
Come-Along or Winch
Gas Can
WD-40 (for those wet distributors)
Spare belts and hoses
Hose clamps (always break)
Water
Coolant
Spare Tire
Beer
Lots o Tools
Ether
Washer Fluid
Squeegee
Clevace
Hitch
Booster Cables
Extra Oil
Extra air filter
Flash light
Duct Tape
Binder Twine (Old red neck back up)
A friend with a bigger truck than you!
Speed = Distance Traveled
black j,
do you mount the hi-lift or throw it in the truck?
i'm thinking about welding a cradle on my brush bar and mounting it there. just trying to get some ideas.
If you go to national 4wd. They have a set of mounting hardware universal for any hi-lift. I think its about 30 bux. Its hardly worth the effort to weld it yourself for that price.
Black j
A tow rope and a friend to pull you out
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
If you are going to carry a Hi-Lift, make sure you have the bumpers that'll support its use. Most stock bumpers would simply fold or rip off.
Sweet! I'll go check it out Monday.Originally posted by black j
Werd. Those things are frigging heavy. I was originally thinking about mounting it on the roof rack, but it was just too much of a PITA and I don't want to risk smashing the window. I'm thinking about mounting to my TJM front bumper, right above the fairlead.Originally posted by IggyB
I think that he's refering to the fact that stock bumpers do not have good lift points. A hi lift only weighs apprx 15 lbs. You could mount it anywhere you want.
BLACK J
A 48" hi-lift weighs 30lb. Maybe you are thinking Kg.Originally posted by black j
I've carried mine on the roof rack when wheeling and now just bolt it to the board under the canopy.
Try the 4 foot jack in the garage to make sure it's long enough to lift the truck. If you have a flexy suspension , you may have to go to the 5 foot model
I'm obviously a poor estimator of weight. But the point is that a roof can easily support a hi-lift if its mounted properly.
most important thing, f000000d
