I have a friend with a 91 Talon TSI and when doing an oil change he over filled the oil pan
My question is, what reprocutions (sp) can happen from this? could his turbo possibly be effected?
thanks for any input guys.
6 liters of fury!
how much over filled?
i'd just undo the drain plug a crack and let some of the oil out. takes 5 minutes.
are u sure its overfilled? most bottles are 4 liters and most cars take around the same..
he was just using quarts (1 litre). i think it called for 4 or a little over and he put in 5.
6 liters of fury!
lol, and most beer cans are ~365ml, but I see drunk people every day.Originally posted by GTS Jeff
You can check the thread out here. There are some ideas on what to do, as well as what can happen. Hope that helps.
5 in the DSM will be fine...it really holds about 4.5 to 4.8 liters, so its really not that much overfilled...you will be ok man, but if you wanna, go ahead and drain half a liter out of the crankcase...
Personally I would just leave it...
...@therealarifjina...
