Lug nut torque? - Beyond.ca - Car Forums
Results 1 to 14 of 14
Thread: Lug nut torque?
    Calgary, Ab
    Default Lug nut torque?
    Where do I find out torque specs for aftermarket rims??
    When mytires installed my tires, they tossed out the boxes and paper (if any) that came with the wheels.
    Damn +44411's
    Apr 2004
    Regina
    2001 Toyota Solara & 1995 Mustang GT
    Check the manufacturer of your wheels website if they have one. A quick google search will help you determine if they do or not.
    Calgary, Ab
    yah, I emailed Axis, as their site lists nothing, and my wheels are discountinued.
    Damn +44411's
    oreo cookie
    a wrx.
    who cares, just torque it on as tight as u can by hand with a tire iron.
    May 2003
    DC4, CB750, CB360t
    This is what I do but I also don't really care about my rims. Either way it's been fine for me.
    Apr 2003
    00 Honda CR-V, 02 IS300
    I thought it was dependant on your car, not your wheels... Your stock specs (if you have a Civic) are 80 foot/lbs... I always set mine at 100 just to be safe...
    STI
    I heard that just making them as tight as posible is bad for the rim and can actually bend them? True?or Fulse?
    if you tighten the lugs too much it can cause warped rotors. i torque mine to about 65ft/lbs
    Dec 2003
    In the dark
    You should torque them to the specs for your car, which is 80 lb ft for a Civic. Make sure you retorque them after driving on them a couple days, and then they should be good.
    I have read that just hand torquing, which leads to uneven torque on each lug can cause things like your brake rotor warping. Overtorquing can also strip your lugs.
    oreo cookie
    a wrx.
    it could, but im sure most ppl can do it accurately enough by hand. maybe if ure really weak u might tire out after the first 3 lugs and torque the last one on very loose or something
    and u would have to actually try to strip the lugs haha
    Aug 2003
    torque to 80ft/lbs like someone said earlier.
    I live my life a beer at a time, nothing else matters.
    Jun 2003
    2019 RS3, Corolla winter beater
    As others mentioned be careful of torquing too tight, that may cause the rotors to warp! Just buy a good torque wrench and follow the manufacturers recommendations for specs.
    Nov 2003
    Cowtown
    N54B30O1
    Lug nut torque is specified by your car manufacturer, not the wheel manufacturer. Reason is that you are actually stretching the bolt and you do not want to overtorque to the point of yielding the threads or the bolt itself. And of course the bolts are part of the wheel hub assembly on your car.
    80 ft-lbs seems to be common in my experience too.
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    alumanim does not like to ressure there are specific torq spec on alloy and other variours metal types due to the fact that if you over tighten a specific alloy or metal, in the event that you hit a nice pot hole or curb good and hard, the rims shatters arround the over tightened lug nuts
    stell rims can be tightened to any torq seetting between 80ft/b abd 110 ft/b depending on the size of the lug nut
    alumanim rims should be anywhere between 35-65 ft/b every time is differnt though its good that you are trying to find the correct torq settings
  1. WTB: Mcgard Lug nut
    By speedracer in forum Automotive Parts
    Latest Threads: 05-05-2003, 06:42 PM
  2. Lug Torque
    By hinggu in forum Mechanical
    Latest Threads: 03-18-2003, 03:36 PM
  3. 4 lug vs 5 lug
    By szw in forum Performance Modifications
    Latest Threads: 12-10-2002, 12:08 AM
  4. Replies: 8
    Latest Threads: 10-29-2002, 09:46 PM
