so i mounted my first cpu evar a couple weeks ago cuz i switched the mobo.
i think i might have used too much thermal grease, but i want to see if the experts agree with me before i take it all back out to remount it.
when i first installed it, the cpu temp was at 55 degrees at idle with the fan running at medium and the comp wouldnt run with the cpu fan at low. but slowly, the idle temp went up until today when it idled at 58 degrees and i crashed when the temp went up to 60 degrees from me loading a playlist. ive turned up the cpu fan to high which is like 8000rpm but its still idling at 56 degrees. the case temp is 35 degrees.
so...too much thermal grease?
