If you have a turbo, supercharged or high compression car/truck this is a must! Also certain vehicles ECU's will take readings from the O2 sensors and adjust timing accordingly to octane levels, so bad or low octane gas the ECU will retard you timing as a result you will loose horse power. Just because you but 92 octane does not actually mean you get 92 octane gas, the octane levels varries per gas batch.
Or if you actually want cheaper gas! You could buy 87 octane from the pump add this get your 94-97 for $2.22 difference.
As per gas prices today; to fill up a 60L gas tank (roughly);
87 = $40.00
89 = $44.00
92 = $46.00
So to add $2.22 to $40.00 will get you you 94-97 octane for $42.22, still cheaper than 89 octane!! So it's kinda stupid not to buy it.
Effectively does the following:
Improves fuel economy up to 40%
Boosts octane number 7 - 10 points
Improves power and acceleration
Enhances combustion
Controls knock and ping
Removes carbon deposits
Here is the stats
87 > 94-97 octane
89 > 96-99
92 > 99-102
I'm only going to carry 2L bottles, which you get 18 uses from 1 bottle.
$40.00 per bottle.
Turns out to be 2.22 at each fill up.
Email me for more details. Order will be placed this wednesday Oct.16. Pickup available that night or any time after that.
Click here to E-mail me.
