Wiring Issue - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Wiring Issue
    Apr 2004
    Holland, NY
    95 contour
    Default Wiring Issue
    Ok i have 2 audiobahn 10's dual dvc 4ohm subs that can operate at 2 or 8 ohms, they are 400 watt rms, and i have them both in a dual separated sealed box.
    My amp is the new MTX Thunder 801d Mono Amp.
    It does-
    RMS Power 12.5 VDC
    2 Ohm Load 500 w x 1
    4 Ohm Load 250 w x 1
    Dynamic Power 14.4 VDC
    2 Ohm Load 800 w x 1
    4 Ohm Load 400 w x 1
    How do i wire the subs for them to hit at a 2 ohm load, and whats the difference with dyamic power and the rms power.
    2001 Honda Civic Coupe
    you can only get 1 or 4 ohms
    RMS power is what you want to look for when you buy audio stuff. RMS is the continuous output/handling whereas dynamic is max output/handling. Not often do you reach max output/handling therefore making those numbers relatively insignificant.
    Nov 2003
    Calgary / Guelph
    Mercedes 190's
    of course you can run these subs at 2 ohms. Go to audiobahninc.com, they have wiring diagrams for each differnet load running different configurations. I believe in the case of the power specs you are getting both are gonna be rms values. The only difference is the voltage they are given at. In a car system, you rarely hit 14.4V and that is gonna be at spikes if you are lucky. So you should be looking at the values at 12V.
    Calgary Alberta Canada
    there is no way that you can get those subs together to achieve a 2 ohm load. either use them as 4 ohm (and get "125w" per sub) or buy another 801d and use one per sub.
    Aug 2003
    Wire them to one ohm.
    You'll like it.
    1993 Ford Probe GT
    You'll like it.
    lol, you are a funny kid...
    certain amps will not run at 1 ohm....they will light on fire....or just slip into protection
    Aug 2003
    Bah, protection proschmection.
    MTX amps will not light on fire at 1 ohm.
    They usually blow fuses though for some reason.
    But they will handle a 1 ohm nominal load.
    The amp will rarely, if ever, actually see that anyways.
    Mmmmmmm 1 ohm.
  1. the new scc issue
    By RiCE-DaDDy in forum General Car/Bike Talk
    Latest Threads: 06-04-2003, 04:01 PM
  2. Jeep Stalling issue
    By JeepBoyCT in forum Mechanical
    Latest Threads: 11-26-2002, 03:39 PM
  3. Issue with Shaw
    By Davan in forum General
    Latest Threads: 11-18-2002, 07:50 PM
  4. My cousins car is on the cover of the Aug. issue of Eurotuners
    By mischief in forum General Car/Bike Talk
    Latest Threads: 08-03-2002, 09:54 AM
  5. Sterio Issue:
    By Ben in forum In Car Entertainment / Electronics
    Latest Threads: 07-21-2002, 01:12 AM
