wheel spacers, how thick untill i need new wheel studs
so i picked up a set of fiero rims with intentions of using them on my spirit so i could use 245's up front and 225's out back. the fronts (backs for the fiero) are 15 X 7, the rears (fronts for the fiero) are 15 X 6.
both will fit on the back, but rub on the front callipers because i went with the daytona 11" vented brakes. i went and picked up some skinny wheel spacers (2-3mm) and tested them on a spare spindel/calliper assembally i have and they did clear (it was close though).
ARP makes wheel studs that are significantly longer and stronger, plus they are pretty cheap at 13 bucks a wheel (i only need these for the fronts), but they aren't made for my car so drilling, cutting, etc. is required and i might not be able to use wheel studs unless i cut them down (i'll probably have to anyways, they are 2 inches longer than stock).
my question is, do i need to go with the arp studs. or is 2-3mm nothing to worry about? this car will see track use and probably slicks, and it will be a high torque application (trying for over 300 to the wheels).
any input would be appreciated.
