What kind of suspension are you running? springs and struts/shocks? what type of camber plates? a lot of camber plates use metal pillow ball mounts, which can make them quite noisy. If this isn't the case, its possible your car is underdamped for your springs, so the car is riding the bumpstops when the suspension is fully compressed. Some companies make a rubber tape you can put over the coils to stop them from clanging together like that, but that might only be a band-aid fix.
