I havent tried octane booster, I figured the 2G DSM's run 8.5:1 compression on premium, so I should have been fine. I'm running the stock ECU and adjusting with the MAF-t. I think my problem is the maf doesnt adjust very accurately. I am only running 10psi (as low as I can). I have just spent the last hour tinkering, and have the knock under control till 4th and 5th gear and it spikes to about 30-33. And if i raise the boost to even 12psi the knock is 40+ in all gears. Let me know what you think and if you need more info.
Thanks
C.J.
1997 TSi AWD 2.3L 6 bolt (Carillo Rods, Wiseco pistons, Cometic headgasket, ACL bearings, removed BS, FP3's, Crower springs/retainers, ARP hardware), FIC 950's, Aeromotive AFPR with SS lines, Walbro 255HP, PTE SCM61, Tial wastegate, Greddy Type S BOV, short route FMIC, 3" turbo back, AEM EMS, 3 bar map conversion, BJs SMIM, 75mm TB, Innovate LC-1 Wideband, 18" Focals, Bridgestone Potenza RE040's, Tokiko suspension.
