If so, where can I pick a can up from?
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
i have heard of it, it was used on monster garage to make a new beatle float because they turned it into an amphibious car :P not sure where to get it though
http://stevenbigler.tripod.com/scoutco/id12.html
It's not a common product and I don't believe its sold in Canada.
try the local napa stores in the city..
I've checked NAPA but haven't found it (yet). I think it'll be a hard one to get ahold of in Canada.
Greg
I dunno why, but this stuff scares the living shit out of me... The thought of an engine ingesting large amounts of liquid is very frightening.
Bought not built!
scares me too, but that gives me all the more reason to try it...
back from the dead ..
I swear I saw this in Calgary at walmart or cdn tire... I should have bought it, it was like $15 or something ..
Please tell me somebody knows where it is in Calgary ...
DannyO
Oh yea, I also met Doris..
I've used it before, you see alot of smoke but it's nothing too scary. I dont know where I picked it up, It's not all that common here.
Have you ever used a VIC before weapon? When you connect a bottle of solvent style liquid into your brake vacuum tube?
sea foam can be bad as if ur rings are worn u might get some blow by after.
But if its good u should gain a few octane from your gas.
Seafoam is awesome. I have a buddy who brought a case of it back from the U.S. Worked amazing on my Stealth. (Good smoke show too). Noticed and increase in power and better mileage. I swear by the stuff. You can't buy Seafoam in Canada.
Appearently it doesnt always have good reviews
Myself, I wouldnt use it. http://www.honda-tech.com/zerothread?id=780762
ran through my stealth as well. It really helps to make the engine quieter. The lifter tick on a 6G72 engine is horrible and the seafoam kills it for about a year.
give it a try. (not available in Canada and you can't ship it because its a hazerdous material)
www.bmwvsmbz.com
I brought some back from Montana. If anyone is interested in trying it out Pm me with an offfer. I have not dyno'd or anything but got a few more mpg and the engine idle is a lot nicer.
White '98 TRD Extended Cab
TRD Supercharger, TRD Long Tube Headers, Borla Exhaust
YotaFab Front Bumper, 10,000lb SuperWinch, Lightforce Striker 170s, YotaFab Custom Rear Bumper, Allpro Sliders
IVD Coilovers, TC UCAs & Spindle Gussets, Alcan Rear Leaf Springs, Icon VS RR Rear Shocks
Tacoma Manual Hub Swap (Warns Temp), Tundra S13WE Calliper and Rotors, Brembo Rear Drums, SS Brake Lines
35x12.5 BFG KM2 Tires, 4.88 Gears, ARB Front Locker, TRD Rear Locker
Painted, Fenders Cut and Bed Bobbed.
Untitled Offroad Team - "See you on the trails!"
A seafoam alternative is the "Cleens" or "Kleens" cleaner found at GMC/Chevrolet dealerships. Roughly $7-8 a bottle and works the same.
Seafoam is excellent for cleaning out carbon. It also smooths out the engine and idle. All in all, very safe to use. I have heard of it causing problems on the rare ocassions, but not a cause for concern.
It tends to smoke the most when you add it into your brake booster. A friend just added it to the motor and gas tank, not a lot of smoke
SHIFT_
As far as I know you can buy a similar product at any local hardware sore but don't quot me on that.
Here's my offer ....
When're you going back to Montana ????
I'm down for getting 2 bottles if you go back ... if you'd be willing to do that.
DannyO
i know a couple people that used it on there 240's and it worked wonders. suggested that its used on older high milege motors(300k like mine) tho isnt it? owell its a great product
Since everyone is telling people to search... I searched... and decided to bring back this thread... Where can I get the seafoam?
I add it to the crakcase before I change the oil (500km? can I change the oil earlier?), the gas tank, and the brake booster line, right? Anyone know where in a b16 the brake booster line is?
Mopar sells the same thing with a different name. It's called Mopar Combustion Chamber Cleaner. You can get it at any Chrysler/Dodge dealership, doesn't matter what kind of car you put it into.
