is shitty throttle response and hesitation at lower rpm due to bad plugs wires cap..etc or is my timing off..thanks
check your o2 sensor it could be shot or clogged
On 2 different occasions I had this problem...once it was due to my plug wires. The second time it was due to a failing O2 sensor, and in this situation I was noticing worse and worse gas milage. I know with my car it never set off a code...cause technically the 02 sensor was working just not as it should have been
check your injectors... maybe put some injector cleaner in your tank and see how that goes...
My friend had this problem once, and it turned out to be his clutch or trans (can't remember ).... really wierd tho.
Good luck, dude!
Besides the above mentioned problems, has your battery died on you recently? If so, it may be time for a new battery.
