Cleaning up overspray... - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Cleaning up overspray...
    Halifax
    98 V70 T5M
    Default Cleaning up overspray...
    My mechanic decided to spray paint his dune buggy in the bay next to my car.
    I now have a nice silver dusting all over my black car. It looks like the car is always dirty now. He's agreed to clean it up, but once he got the $400 quote from a detail shop, he decided to do it himself. I left the car with him for a day, and came back to find only the roof cleaned up. He was using some sort of putty to get it off (no clue what it was) and it seemed to be working, but it made the paint look like hell. I'm getting a little sick of his procrastination and want to get things going on my own. Any recomendations on how to clean this up? What products, processes to use, etc?
    Apr 2004
    Regina
    2001 Toyota Solara & 1995 Mustang GT
    He could try a reducer, if the overspray is fresh that should remove it no problem. If your car has never been repainted, thinner will work without damaging the paint. It can be buffed with compound and then glaze. It can be wetsanded and polished. All of these depend on the severity of the overspray and the experience of the person doing the work. Hope this helps.
    Feb 2003
    chestermere AB
    03' SVT Cobra 10th ann vert
    repaint it, easiest ways to do it , if you use thinner it will dull out the paint and look different in surtain areas, and to wet sand you need to take it to a pro and will cost as much as a new paint job. buffing simply wont work and is hard work even if it does work
    Apr 2004
    Regina
    I disagree, you don't need to repaint it. Repainting is excessive and expensive. Wetsanding when done properly is a fraction of the cost of a paint job. We surely don't charge near as much as a paint job for wetsanding and polishing after. If the car has never been repainted, gunwash thinners do not affect the finish.If someone is stupid and leaves thinner sitting wet on the paint is will dull it. There are many reducers designed to cut paint when fresh as well. Anything you use must have a glaze applied afterwards. Detail shops and autobody shops clean overspray off all the time.
    Halifax
    98 V70 T5M
    Well, the spray paint has been on the car for a little over a week now and the car was repainted once. I guess that limits my options. It is after all my mechanic's responsibility to get it cleaned up, I just want to get things rolling. What would happen if thinner was used after the car's been repainted?
    Jun 2003
    Canada
    GMC Sierra
    "Clay Away" or a clay bar should get rid of all the overspray, you can find this at most automotive stores. You will need to cut and polish after that is done.
    Apr 2004
    Regina
    If the car has been repainted thinner will damage the finish. The longer the overspray sits on the harder it is to get off, why not take it to the detail shop and make the mechanic pay for it? If you owe him money for something he has done for you it should make it easier for you to just get it done yourself.
    Halifax
    98 V70 T5M
    Took me a while, but I finally got some pics of the damage. I've left it for so long that I think it's going to need wetsanding.
    that's ridiculous... get him to take off the overspray...
    you shouldnt even be concerned about how YOU'RE going to fix it, because you shouldnt have to in the first place. how could you paint next to a car at all? what a retard.
    Halifax
    98 V70 T5M
    Yeah, I wan't too impressed either. The problem is that I've been dealing with this guy a for a long time, and he lets me use his tools and hoist when I need to, he gives me good deals and whatnot. He is going to take care of it, but I just want to make sure it gets done properly. What I'm trying to figure out is what this kind of job should cost. I owe him some money for some work, so we might just call it even and I'll take it to a detail shop or something.
    Here's another shot.....the entire car looks like this
    Feb 2003
    chestermere AB
    is it craking it looks like it?
    Aug 2004
    Thunder Bay, Ontario
    93 Toyota Pickup
    well why not just totally repaint the car red or something? :P that sort've looks cool, might be diff in person - looks like un-mettalic mettalic paint
    Originally posted by Grogador
    Shoulda threw in a "no homo" somewhere... cuz... yeah...
    Originally posted by turbotrip
    seems like a recipe for rape
    toexistphoto.com
    Feb 2004
    1996 Honda Civic Si
    Whatever you do don't use thinners on the paint! Try a rubbing compound. You put it on the surface...let it set for a few minutes, then take a buffer/polisher and it should do it, might take some time but it's gonna be cheaper than taking it to some shop...At the shop I worked at we had a rubbing compound from a company named APC (No, it's not the one that makes all those ricey car products), it always came in a large bottle, kind of blue-ish green in color. Try Carlson's Paint and Body Supply up by Deerfoot Mall, that's where we got ours Their number is in the phonebook too if you would rather call first......
    Apr 2004
    89 240sx
    check out napa the other day when i was there i saw a product called overspray remover. just ask any one of the guys at the counter of the store and they will have plenty of info for you.
    ed
    Okay,
    Ive had lots of experience in this.
    Just go to your local crappy tire and pick up the Meguirers clay bar kit. Claybar's main purpose is to remove overspray and other impurities that have "etched" their way into your clear coat.
    It comes with their quick detailer and the clay bar. Just soap the car up and wash it like you normally would.
    Then you take the quick detailer spray bottle and mist the car and rub the clay bar back and forth making sure you keep the surface well lubed. Once you do this the paint will look like new. Read the instructions and you will be fine and the car will look better than ever!
    Best part is an entire car takes roughly 3 hours with a good waxing afterwords and you don't have to cough out tons to a body shop to do the same thing.
    lam-boy Guest
    Originally posted by lowryder99
    Okay,
    will it work even if the overspray on my car is like 1 yr old?
    i have some crap ass blue overspray...
    ed
    If you really take your time with the clay bar system it will take the overspray off. How much your car is in the sun is a big factor as well and how often you wash/clean your car.
    Ive had overspray on my truck before for 6 months at a time and removed it with the clay bar sytem, it just takes a lot longer and you have to be more careful doing it.
    Overspray is usually never permenant because there is no prep work involved (obviously) therefore it can never find a good surface bond except for todays modern clear coat's which are incredibly soft, once you get it out of the clear coat your gold
    vancouver
    01 mazda protege es gt
    lowryder99....you da mang..everybody listen to this guy that is EXACTLY how you do it. i've spent many a year detailing and still do for high end cars clay bars are the SHIT!!!!! works awesome, easy to use, just did an 04 m3 cabrio...turned out better then when he picked up his car from bmw!!cust was really happy!
    low 'n' slow
    ed
    Ive painted and detailed cars for awhile now, im still working on my painting but my detailing is where I shine
    R6..
    try low grade thinner, works for me...
    a bee nearly took my head off goin 220... $#@%ing bee
  1. Cleaning Out Sale
    By CrAzY_PLaYa in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-03-2003, 09:48 AM
  2. wtb: aem filter cleaning system
    By Seks in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-25-2003, 01:39 PM
  3. cleaning puke
    By Lo)2enz0 in forum General Car/Bike Talk
    Latest Threads: 01-12-2003, 05:17 AM
  4. FS: GEN5 Prelude Parts..cleaning out the garage.
    By VTEXTC in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-30-2002, 12:53 PM
  5. Cleaning the engine bay
    By Rydog in forum General Car/Bike Talk
    Latest Threads: 06-27-2002, 08:30 PM
