Petro Canada gas -- Effect of additives on gas mileage - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Petro Canada gas -- Effect of additives on gas mileage
    Hybrid
    Question Petro Canada gas -- Effect of additives on gas mileage
    The rising gas prices have got me wondering... with all of the additives that Petro Canada puts in their gas - "tactrol" (now 50% more), antifreeze, corrosion inhibitor - would it decrease gas mileage?
    My thought would be that the more "other stuff" in your gas, the less gas there is and the less mileage you'll get.
    I've never filled up anywhere but petro canada (petro-points), so does anyone have any experience with Petro canada mileage vs. other gas?
    ecstasy_civic's Avatar
    ecstasy_civic is offline MMA guru, but still rage2's bitch
    Aug 2002
    08 Si
    Default Re: Petro Canada gas -- Effect of additives on gas mileage
    I only use petro as well, unless I have too, I use Esso.
    Just cause of the petro points as well lol.
    But usually it seems alright, Esso goes alot faster and harder on the wallet
    Jul 2003
    98 civic hatch
    i doubt it, those additive contribute to only a very very small percentage of the actual amount of gas u recieve, all gas has additive just some companyies like to advertise it more...
    Oct 2002
    Lurking in some bushes outside your house
    S14/D21
    I used to use Petro Can all the time. A few months ago I switched to Shell to see if there was any difference. I was surprised...I got alot better mileage from the Shell gas.
    Nov 2003
    2009 Elantra Touring
    You shouldn't really worry about the additives, the main benefit of the additives is they help keep the fuel system clean.
    If there is one additive that you should avoid, its MMT - problem is, its legal in Canada, and even worse, gas companies do not have to make available whether or not they use MMT in their fuels. I know that Mohawk/Husky doesn't use MMT.
    MMT artificially raises Octane and most "octane boosters" are a mix of denatured gasoline mixed with a high concentration of MMT. MMT however contains manganese which reacts with the metals in your catalytic converter - your catalytic converter should technically last a lifetime because everything inside it is a catalyst - as opposed to a consumable material. When MMT flows through the cat though, it converts the metals to salts/gases which eventually destroys the effectiveness of your cat.
    If you don't care about the environment though, then even MMT shouldn't be much of a concern.
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    I tried safeway's, centex, shell, esso, pretty much every company in the city (even though it's all pretty much the same), and Ifound petro canada gave me the best mileage. Not by a lot, but with prices this high, everything helps. I tried to keep my driving pretty constant between all the different brands, but I did see about a 5% increase in fuel economy from petro canada. Between that and the petro points, I'm sold.
    I think I can get about 15 cases of pepsi by now, lol.
    i find i get slightly better gas mileage on petro canada gas too. plus cheaper gas with the petro points card
    the opposite for me. I find petro give me consistantly 50km less a tank.
    Esso gives me the best mileage followed by shell.
    9.872604, -85.498802
    Turbos n Stuff™
    Meh, I have no cat and I run rich. I know for a fact I get the worst milage on Mohawk 94, and the best on Shell 91. Not sure why.
    Travel
    I did some mileage tests a while ago, and found Shell to be the best, and Mohawk to be the worse.
    The reason why Mohawk has such poor mileage is because of the ethanol blend. Assuming the same amount of fuel injected for the same amount of air, ethanol blended fuels will show up leaner on the O2 sensors. So in closed loop day to day driving, the ecu will automatically adjust by injecting more fuel for the same amount of air in the motor, thus worse fuel economy.
    Also, with higher octane fuels, knock limits are higher (good for turbo or if u can turn up timing) but the actual energy content of the fuel is lower. Therefore, you'll be making less power assuming the ecu tune does not change. To maintain a certain cruising speed, you would need more throttle, more air, thus more fuel. This is also why a car designed for and works optimal on 87 octane fuels will see a decrease in mileage when using 91, 92, 94 octane fuel.
    Not sure exactly what Shell puts in their fuel that helps fuel economy so much.
    Turbos n Stuff™
    Sorry, this is what I was wondering, I know why I get the worst on Mohawk, should have clarified that, howevere very usefull info for those who were unsure.
    Moreover in regards to shell, I get better milage on their Premium 91 than the Bronze 87. I made the mistake of putting 87 in my car, and asside from it running like ass (felt like it was 40 degrees out and 100% humidity when driving after I put 87 in) it got about 50-60km less on a tank.
    Travel
    Hybrid
    Thanks guys....
    Looks like my next tank will be shell 91. Do they offer cents off at the pumps?
    For everyone who's collecting petro points, I think they're offering double petro points for the next few months on premium to promote their new 50% more tactrol... Plus, if you get a superstore mastercard, you can get PC points which you can convert to Petro points (what i've been doing)...
    Hybrid
    I'm saving my points for a free membership to the petro canada auto club... 40k points... which is hella easy with PC points on my mastercard... all I have to do is pay tuition, and I get enough points
    Dec 2003
    Wut is the Petro auto club?
    Feb 2004
    Calgary, alberta
    996TT
    I foudn esso to be the best. fgollowed by shell.
    It's like AMA but it's run by petro-canada, shit like boosting your car and unlocking your doors. Pretty handy to have IMO
    I personally don't like using Petro Canada fuels, becuase their 91 octane has the lowest knock threashold of all premium fuels. Have to lower my boost settings!
    Jul 2003
    NW
    i remember hearing something about shell's gasoline have less addictives and filters out a content of some sort(i think it relates to grease?) the best compared to other companies. and doesn't co-op use shell gas?
    Jan 2006
    I only use Shell in all of my vehicles. Best gas I've ever run.
    A 16 year bump
  1. The Butterfly Effect
    By TalonVelocity in forum Entertainment
    Latest Threads: 02-14-2004, 01:23 PM
  2. Calculating Gas Mileage?
    By rewecow in forum Mechanical
    Latest Threads: 11-03-2003, 11:02 PM
  3. Gas mileage is horrible
    By redline_13000 in forum Mechanical
    Latest Threads: 09-18-2003, 01:29 PM
  4. gas mileage on prelude
    By 2.2vtec in forum Mechanical
    Latest Threads: 03-10-2003, 08:23 PM
  5. Does the Tornado air thing work? Or have suggestions to boost gas mileage
    By kboxster in forum Performance Modifications
    Latest Threads: 01-24-2003, 08:47 AM
